Is this a good measuring caliper?
I picked up a digital measuring caliper (6") from harbor freight today, it seems pretty good, they say it measures down to .001 or .0001, but i go to measure wheels they say are 28mm, and they turn out to be like 28.22mm. Is this because of my caliper, or is it because the manufacturers measure to the nearest whole number on wheels?
28.22 v. 28mm?
Not bad! My Jaco 28mm were closer to 30mm [got curious after they were rubbing and measured]. Your caliper, as long as you follow Guns' advise by setting it to zero, should be good-to-go.
I got a set and its accuracy is rated to .03 as a margin of error.
^5
^5
yeah its great that what most of the guys at my track use and it works well so you should have some luck with it
Originally posted by Tom G
28.22 v. 28mm?
^5
28.22 v. 28mm?
^5
Checked out the caliper, looks very, very similar to mine [no black inlay on the ruler portion] and I have the 8in version so I can use it to measure track width [it is a bit clumsy in some tighter areas of the chasis to use though]
^5 again
