i need some help with this >
Old 08-29-2004, 10:01 PM
  #16
i dont even think they make a steel spur gear(im not sure though) because it would add a ton of roataing mass and therefore decrease acceleration jarasticly and in the 2 years i have been racing i've only stripped around 2 spurs so your best off with plastic
Javen13 is offline
Old 08-30-2004, 04:21 AM
  #17
yea i wasnt sure about that but i thought i saw one before.
rcbrnt676 is offline
Old 08-30-2004, 07:31 AM
  #18
i noticed that the charger you picked out was dc only so u have to run it from a 12v power source such as a car battery or power supply
Javen13 is offline
Old 08-30-2004, 02:06 PM
  #19
Thumbs up
o crap im happy i didnt buy that yet lol thanks... but everything else will work together right.......
Old 08-30-2004, 02:11 PM
  #20
will this 1 workhttp://www2.towerhobbies.com/cgi-bin...?&I=LXWL89&P=7
with this batteryhttp://www2.towerhobbies.com/cgi-bin...?&I=LXGJP9&P=M
Old 08-30-2004, 06:59 PM
  #21
yup they will work together the only thing is the conectors may not be the same so u may need an adaptor but thats about it you may not even need the adaptor
Javen13 is offline
Old 08-30-2004, 07:33 PM
  #22
Thumbs up
tech forums i sthe best i never got this many reply on other forums thanks alot for u help when im done with my car il poast a pic of it or ill send u one.
Old 08-30-2004, 07:34 PM
  #23
sry i cant type ill post a pic when im done with it or send it to u by email.thanks again
Old 08-31-2004, 04:33 AM
  #24
X2
X2's Avatar
Originally posted by Javen13
the tc3 stock comes with a 72 spur so u will have to order a pinion for the motor i would by 3 or 4 pinions to experement with maybe in the 18-24 range if u want top speed
A 24 tooth for top speed? Thats REALLY small, I take it you race indoors or on a small track all of the time?
At my local outdoor track (average sized) in a TC3 anything under 32 teeth is considerd undergeard.
X2 is offline
Old 08-31-2004, 07:57 AM
  #25
the tc3 comes with 48 pitch spur gear were u race they most likely use 64 pitch because on my tc3 i run 64 pitch and run a 33 tooth pinion so a 22 in 48 is evual to like a 37 or so in 64 pitch
Javen13 is offline
Old 08-31-2004, 01:49 PM
  #26
Thumbs up
so like a 35/40 umm i really am bad at gearing really bad ok so if im wrong tell me. thanks!!!!!!
Old 08-31-2004, 02:04 PM
  #27
onnetz's Avatar
with the stock 48p 72t spur a 32 pinion wont fit in a tc3.
at least not in mine..
onnetz is offline
Old 08-31-2004, 02:09 PM
  #28
i kno the highest 48p pinion i put in with a 72t spur was a 31...i dont remember tryin much more than that....i have also had some work done to the motor mounting cam, but that was after i ran 31t pinions
punkboy is offline
Old 08-31-2004, 02:31 PM
  #29
like 4 a novak brushless what should i do...sry.. i ask alot a questions!!it is this model her is the pic but it only shows the esc the motor specs r at the bottomhttp://www2.towerhobbies.com/cgi-bin...8&I=LXDDD7&P=K thanks so much for helpin me out this long!!!!!
Old 08-31-2004, 03:06 PM
  #30
for the brush less you may want to try a 27 or so to start with i think its robison racing that sells all the odd or all the even pinion numbers so u may want to try that
Javen13 is offline
