Old 08-28-2004, 10:17 PM   #1
ajg
Registered User
ajg's Avatar
Motor spring tension
Does softer or harder springs give you more speed?
I'm using an Epic binary2 10 turn.
Thanks.
ajg is offline   Reply With Quote
Old 08-28-2004, 11:49 PM   #2
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
More timing gives you more speed....but lighter springs will give you more top end and stiffer springs will increase torque.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 08-29-2004, 12:29 AM   #3
ajg
Registered User
ajg's Avatar
Thanks, I went to softer springs, but wasn't sure if it would give me more speed. I'm also running 25 degrees of timing.
Old 08-29-2004, 02:24 AM   #4
Maybe turn it up to 27 or 30 degrees. Then put on slightly stiffer springs to compensate for low end loss. Should be dialed.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 08-30-2004, 08:34 AM   #5
I thought you already had the motor dynoed to 64,000 rpm?
Keep heavy springs on your 10 turn, and make sure you cut the comm every several runs.
TPJ International
071crazy is offline   Reply With Quote
Old 08-30-2004, 05:34 PM   #6
ajg
Registered User
ajg's Avatar
I clean the comm after every run (each run is a few second long) and I cut the comm quite often.
Thanks guys.
Old 08-31-2004, 07:05 AM   #7
Thanks guys.
You probably dont need to "clean" the comm after every run. In fact, it might do more damage than just leaving the motor alone in between cuts and new brushes.
TPJ International
Old 08-31-2004, 07:13 AM   #8
ajg
Registered User
ajg's Avatar
Oh, Alright.
Old 09-01-2004, 03:16 PM   #9
This is why I don't use brushed motors. To much work.
Keep us posted AJG - Let us know hwo the motor performs after you get everything back in the car.
studysession is offline   Reply With Quote
Old 09-01-2004, 07:05 PM   #10
EddieO's Avatar
R/C Tech Charter Subscriber
Well, if top speed is what you are after....I would not use a heavy spring.....try to spring as soft as you can without the comm buring up from too much arching. Remember that the if you overspring, the brushes will act as a drag brake and will limit your top speed.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 09-01-2004, 08:07 PM   #11
ajg
Registered User
ajg's Avatar
Thanks eddieO, I'm using green on one side and purple on the other. Is that good? (trinity springs)
Old 09-01-2004, 08:14 PM   #12
EddieO's Avatar
Well, thats a pretty big spread.....not to mention a purple is the 2nd heaviest trinity spring....try a red on the positive and green on the negative....possibly even see if you can run a green on the positive...continue to spring up both sides until you get slower. I would never be more than one color apart either(though you can bend them a bit to get a little more or less if needed). The positive side should always have a higher or equal spring....never spring higher on the negative regardless of what any retard tells you.
Trinity Springs in order of tension (highest to lowest)
Silver
Purple
Red
Green
Blue
Later EddieO
www.teambrood.com
Old 09-01-2004, 08:18 PM   #13
ajg
Registered User
ajg's Avatar
Thanks alot EddieO.
*** Motor Alignment Bars and Spring Tension Checker $20 shipped swopemike R/C Items: For Sale/Trade 3 12-09-2007 08:22 PM
xray spring, AE spring, drop block, sevo, motor, pinion, power supply, brush cutter maximebeauvais R/C Items: For Sale/Trade 3 01-25-2007 02:09 PM
Motor, Brush and Spring tools, incl. Spring Thing rccardr R/C Items: For Sale/Trade 4 10-22-2006 12:11 AM
spring tension Racingfreak6 Electric On-Road 2 08-12-2006 07:20 AM
NifTech Ultra Precision Brush Spring Tension Measuring Tool TigeRyan R/C Items: For Sale/Trade 1 09-08-2004 12:57 PM
