Hard tires
Old 03-04-2011, 06:02 AM
Default Hard tires
Hi
I need some really really hard rubber tires with low grip.
1/10scale touring tires.
Any suggestions?
MatsNorway is offline
Old 03-04-2011, 07:39 AM
RossoTorro's Avatar
Orginal Tamiya kit tires?
RossoTorro is offline
Old 03-04-2011, 08:07 AM
There must be some harder tires out there. Besides My brushless probably rips them into pieces.
Old 03-04-2011, 08:31 AM
Xpress's Avatar
Jaco blue
Xpress is offline
Old 03-04-2011, 08:59 AM
tc3team's Avatar
HPI X pattern are rather hard. (Or maybe mine are just very old?)
Or Sorex 36???
tc3team is offline
Old 03-04-2011, 05:52 PM
Tamiya drift tyres (type d ??)
very hard rubber (sort of)
Low grip, by design, but more grip than plastic drrifttyres
1101 is offline
Old 03-05-2011, 03:11 AM
Sounds like a good start..
rubber drift tires. the way it should be.
Old 03-05-2011, 04:31 AM
I was in the same need for some low grip , hard tires 'cause I can run in a Gym.hall with a polished wooden floor . For roadcourse racing all tires I tried had to less grip , even the softest with soft inserts . So I changed my mind to drifting , but found out , all drifttires have as little as no grip , made an awfull noise and left unwanted marks on the floor . So I ended up with Tamiya kit tires insertet with a ring cut from a plastictube and stuffed with hard foam . Those work perfect on my TT01 Drifter . The iserted plasticring makes the runningsurface of the tire hard as rock , ceates nearly noise , leaves no marks on the floor , has the good grip needed for drifting and seem to last for ever.
Rockopa is offline
