not again!
Old 08-28-2004, 10:33 AM
Exclamation not again!
my new element motor is not working? its comm just got cut and its got brand new brushes but when its all hooked up to my tc3 and i pull the trigger the car does not move? i have reset the esc which is the stock one, i have sprayed the motor out, my servo works fine and when i put my multi meter on the motor tabs (unconnected) its getting full power? but when its sitting on the ground not moving and you give it a little nudge it will move but the minutes you stop it, it quits? i have no clue whats wrong i have brand new batterys in my car and controller
but i have noticed that when i take my motor apart to clean it and put it back together the armature seems to be scraping against the magnent in the can but after you spin it like 5 times in you hand it no longer scrapes i dont know if this has anything to do with it but i'm just trying to rule out every possible thing?
i dont think its my esc because the led works and my servo works
and when you go full throttle the led turns off and thats what its supposed to do so i have no idea????????????? please help!!!!
kh15 is offline
Old 08-28-2004, 10:36 AM
StephenSobottka's Avatar
Sounds like a hung brush. Even though they are new and your comm is cut this can still happen if the hoods are tight, Give them a snap and you should be back in good shape.
StephenSobottka is offline
Old 08-28-2004, 10:49 AM
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
most likely a hung brush as Trinityracinnut said. in addition, if the hoods are a bit tight, try to loosen the crimped brush hoods with a small flat screwdriver gently... that might do the trick
Tommi Makkinen is offline
Old 08-28-2004, 03:46 PM
so just take the brushes out and pry open the hoods alittle and put them back in?
kh15 is offline
Old 08-28-2004, 04:19 PM
GundamWZero's Avatar
Yup, just a little. But when you remove the brushes, see if they have problems sliding out. If they are tight sliding out, then the hoods are slightly misaligned and pinching the brushes in place. I would invest in a hood alignment tool as well.
GundamWZero is offline
Old 08-28-2004, 05:20 PM
i just ran it about 5 minutes and everything seems to be normal again but i will be running it intill the battery goes down later, thanks for the good answer, on another rc forum i posted this question like a week ago and after 15 replys nobody said anything about the brush hoods, next time i'll come to the pros first!
kh15 is offline
Old 08-28-2004, 06:02 PM
Thats right!
Old 08-28-2004, 10:06 PM
lol how could i be so stupid
kh15 is offline
Old 08-29-2004, 05:26 AM
dont call yourself stupid, bro... just consider yourself unfortunate... at least you didnt get frustrated enough to get mad... enjoy racing!
Old 08-29-2004, 09:00 AM
Also...
DId you after you cut your comm... Take an exacto and run it in the slit on the comm. Then take a ball point pen and light roll it down the comms slit edge, this will round over the possible sharp edge.
Smalls is offline
