cleaning bearings?ultrasonic? >
Old 08-28-2004, 01:30 AM
wothrottle's Avatar
Default cleaning bearings?ultrasonic?
Hi,
I just started cleaning my t4 bearings,removed the shields soaked them in thinner,toothbrushed them and blow them out with compresed air.4 of the bearings are so gritty,I think these are from the the drive axle,and wouldnŽt become free.What else can I do,do you recommend ultrasonic cleaning for that?
wothrottle is offline
Old 08-28-2004, 01:37 AM
GTO2's Avatar
i would dunk them into WD for few hours and clean again with airgun.
From my experience some solid dirt just won't come off even using an us cleaner.
Probably busted bearing as well.
For maintenance use, us cleaner is quite good...just can't stand the high pitch humming sound
GTO2 is offline
Old 08-28-2004, 02:23 PM
Sny
Sny's Avatar
Nothing beats a ultrasonic bath for bearing cleaning. Use a penetrating lubricant (WD40 is good) I use 1:1 Acetone/Toluene mix. Buzz the bearings in the bath until the solvent turns darker, rinse and repeat. Those bearings will be cleaner than the day they were made.
Sny is offline
Old 08-28-2004, 02:26 PM
wothrottle's Avatar
thank you guys,IŽll try this as soon as I got the us cleaner.
Old 08-28-2004, 03:07 PM
RCTech Member #2
TSR6's Avatar
I just let mine run in the garage. I do it for a couple hours..... dump it out, rinse, then just let it run overnight.
TSR6 is offline
Old 08-31-2004, 06:49 AM
Speed Demon's Avatar
back to this topic.... question to the us cleaner owner/user...how much power is enough for the ultrasonic cleaner? I mean the US cleaning power?? is 35watt enough??
thanks..
Speed Demon is offline
Old 08-31-2004, 07:51 AM
Well, I use an Elma 45W ultrasonic cleaner and it's great.
But, there's a warning against using flammable liquids (danger of explosion or fire), so I only use water with soap!! 15 min and that's all.
How about you Sny?
gearless is offline
Old 08-31-2004, 11:07 AM
Sny
Sny's Avatar
Well, I use the ultrasonic bath at work, so I'm not too worried if it catches fire. It is always a good idea to be careful, but that said I have had all kinds of stuff (and some of it for work purposes, I work in a chem lab) in our us bath, no problems or nasty surprises so far.
Sny is offline
Old 08-31-2004, 09:16 PM
sny, if I but the us cleaner rated 35W, is it powerfull enough for cleaning the bearings??
Old 08-31-2004, 09:43 PM
Trader Rating: 16 (100%+)
Please note that acetone and especially toluene are nasty chemicals. Consult MSDS information for proper handling and disposal of either chemical. Neither substance is for kids.
But thanks for the idea of using ultrasound to clean my bearings.
Still Bill is offline
Old 09-01-2004, 08:46 AM
GTO2's Avatar
Dang, you guys use 35-45W US cleaner... that's enough power to clean the whole car (j/k) I do envy you guys.
I only have a pathetic 300mW cleaner no wonder some dirt won't come off.
The idea running in garage is cool tho....but I won't use flamables liquid on unattended overnight run if that is what you mean, just to be on a safe side.
GTO2 is offline
Old 09-01-2004, 08:51 AM
RCTech Member #2
TSR6's Avatar
The Integy Indi Sparkle runs off batteries. It's what I use...
TSR6 is offline
Old 09-01-2004, 09:00 AM
GTO2's Avatar
I see.
Mine is about the same power i suppose.
GTO2 is offline
Old 09-02-2004, 11:34 AM
Sny
Sny's Avatar
I am not sure the power of the ultrasonic unit at work, but I'd guess it is pretty powerful. And yes, be careful with the acetone, especially with plastic parts (they dissolve in acetone).
Sny is offline
