Old 11-12-2007, 12:10 PM   #1381
Dredd~no peoblem
Andrew,
I actually run my GTB on the other side of the car and the "flip" the servo so it is on the other side as well. my car balances with no weight.
Greg Anthony is offline   Reply With Quote
Old 11-12-2007, 02:58 PM   #1382
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
So you run your servo and your GTB on the left?
Could I e-mail you for a pic perhaps? I'd love to get this all figured out. How are you determining that the car is balanced left right? Or are you just eyeballing it and saying "good 'nuff."
Old 11-13-2007, 07:41 AM   #1383
andrew. yes, I run my KO 949 and reciever on the on the left side of the chassis, and the GTB on the right.
I use X-Ray balance pins to balance the car.
Old 11-13-2007, 07:42 AM   #1384
Bruce,
YGM
Old 11-13-2007, 11:06 AM   #1385
Rev 4.5 or 5? I don't know much about all the different cars yet, but I know my 4.5 doesn't have holes in the center for balancing. Is that something I could have done by speedmerchant if I were to buy one? The one I currently have also does not have the servo saver cut out. I had to dremel it out, but the reliefs at the front of the chasis limited how far forward I could dremel the hole which in turn limited how far forward I could mount the servo, which in turn limited my choices in mounting the esc. I had to use 3 layers of servo tape to get it to hover over the battery placement bar screws. Anyway thanks for the info Greg. Much appreciated.
Old 11-13-2007, 11:35 AM   #1386
beavis353's Avatar
Drew,
The Rev 5 comes standard with the holes in the center of the chassis and the lower rear pod plate so you can use the balancing pins. In my case, the chassis Im currently running was pre-production, so i used calipers and drilled my own holes. I marked the centerline of the car front and rear and the rest was history.
In regards to your servo location... Using the old skool front end, it is critical from an ackerman standpoint to have your servo all the way forward, touching the rear of the suspension arm. The medium black Kimbrow servo saver you are suposed to use fits nicely in the Rev 4 chassis you were referring too as long as you grind about 1/3 to 1/2 of the graphite away thats immediately below the horn. There is no reason to go all the way through the chassis. The Rev 4.5 had shorter front chassis cutouts, and a small hole for the servo horn so you didnt have to do this.
Im sure I have my old rev 4 chassis sitting around here somewhere if you need a pic.
BEAVIS
beavis353 is offline   Reply With Quote
Old 11-13-2007, 12:11 PM   #1387
xtreameracer's Avatar
Send a message via Yahoo to xtreameracer
when are the parts for the rev 5 going to show up on the web site , its said by next week but its been atleast 2 weeks since that?
xtreameracer is offline   Reply With Quote
Old 11-13-2007, 02:58 PM   #1388
Originally Posted by beavis353 View Post
Drew,
BEAVIS
wow, thanks for all the info. Looks like I might have a rev 4 chassis with the 4 bolt rev 4.5 rear end. I will have to see about getting a ev 4.5 chassis or maybe upgrading to the 5 as I am planning on running BL only. I guess I will jsut run it for now though since its all shoe gooed in the BL is wired up nice.
Old 11-13-2007, 09:34 PM   #1389
Bevis,
shoot me an e-mail bro..... [email protected]
Old 11-14-2007, 07:57 AM   #1390
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
A few photos of my Rev4.5 LRP Brushless. Built by Mike O'donnell...
Speedmerchant Rev.4-rev-4.5-brushless-img_0010.jpg   Speedmerchant Rev.4-rev-4.5-brushless-img_0009.jpg
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-14-2007, 08:57 AM   #1391
beavis353's Avatar
No problem man. Let me know if you have other questions. If your looking to do brushless only, you really should look at the Rev 5. They are backordered at the moment, but as soon as the initial demand dies down they should be available without any waiting.
Beav
Old 11-14-2007, 09:03 AM   #1392
beavis353's Avatar
Almost forgot. If your a Team McGoo Factory Driver, check out Marc's new Rev 5. Its a true "Beavis Edition".
Old 11-14-2007, 09:57 AM   #1393
Mr. McGoo's Avatar
I will get some pics up soon.....
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 11-15-2007, 06:26 AM   #1394
Beavis,
Thank you.
Old 11-15-2007, 07:59 AM   #1395
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
When are you going to run that "SHELF QUEEN??".......
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
