Old 02-27-2007, 11:42 PM   #1186
Got a couple questions, haven't run 12th in a long while.
Do you run a cap on the speedo, and if so how big?
With the strut front end, do you run the servo on angled mounts or flat on the chassis?
What is a decent starting setup for running stock with the strut front end?
Thanks for any help.
JoelV is offline   Reply With Quote
Old 02-28-2007, 05:05 AM   #1187
Trader Rating: 8 (90%+)
I run a Novak 680uf on my GTX. I have no problems with it.
SpeedMerchant drivers dont use the strut front end.
This setup was really easy to drive for stock. The strut should use the same setup as the old skool.
.020 Front Springs
Lowered Steering Blocks
.5* Toe out
6* Castor
40wt Shock Oil
Red Center Spring
Battery Forward
About 2* Droop
About .25 mm Sag
White Side Springs (New Style)
1/8 turn preload
Ride Height 3.5mm all around
CRC Blue In The Tubes
Parma Magenta Fronts / 1.68
Parma Pink Rears / 1.73
Johnny Carey is offline   Reply With Quote
Old 02-28-2007, 08:42 AM   #1188
beavis353's Avatar
Uhhh Johnny....
Real men run grey rear Parmas in stock.
beavis353 is offline   Reply With Quote
Old 02-28-2007, 08:58 AM   #1189
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
I am looking for a manual for this car, my computer is way to slow to download each page.
roadrashracing is offline   Reply With Quote
Old 02-28-2007, 09:01 AM   #1190
Originally Posted by beavis353
Uhhh Johnny....
On low bite!! Naww... I run pink bodies anyway.
Old 02-28-2007, 10:54 AM   #1191
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
Here is my current setup Joel, car works amazingly well at RCE when grip is where it has been. This is with the 10' reactive front end, I am using IRS lowered arms and CRC upper arms with the rest being regular off the shelf AE parts.
Straight Links (No Ackerman)
.020 Front Springs
1/2' Toe In
Castor Shims 1 & 1
45wt Shock Oil
Blue Center Spring
Battery Back
About 1' Of Pod Droop
About .25mm Of Pod Sag
Blue Side Springs
Just Enough Pre-Load To Tweak
3.5mm Ride Height Front & Back
OFNA 10,000wt In The Tubes
Jaco Grey Rears Around 1.75
Jaco Purple Fronts Around 1.68
Parma Speed 8 Lightweight Body
Team Kwik Stickers
Give it a shot, works for me! I will be more than happy to help with the car if you need it, you know me.
Nick
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 02-28-2007, 10:59 AM   #1192
timmay70's Avatar
You forgot to mention exactly where to position the Kwik stickers... weight distribution matters a lot...
I may have to try the newer AE style front end...
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 02-28-2007, 11:51 AM   #1193
odpurple's Avatar
That sounds like a good set up. Is this with the servo mounted flat?
How much faster is it with Team Kwik stickers? Maybe I's better get some
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 02-28-2007, 12:00 PM   #1194
Team Kwik's Avatar
We are finding them very similar in power output to the Japanese or Chinese writing stickers you see on many Hondas these days. If Shawn can just get a little more power out of them we might just start targeting the automotive market =)
Yes, that's with the servo mounted flat on the chassis.
Nick
Team Kwik
Old 02-28-2007, 12:10 PM   #1195
odpurple's Avatar
Nick
You could try translating "Team Kwik" into Japanese
Old 02-28-2007, 01:39 PM   #1196
Nick will you be there next Tuesday or are you off to Michigan?
I need to drill holes in the chassis for the servo. Bruce suggested taking the hyperform chassis I have and lining up the holes where the front suspension is bolted and mark the holes and drill like that. Would that be the easiest way?
Also what's the difference between tire compounds? I've heard purple/grey a lot, and magenta/gray a lot. Does it vary between Jaco and Parma?
Old 02-28-2007, 09:22 PM   #1197
Team Kwik's Avatar
Pure genius!!!
Team Kwik
Old 02-28-2007, 09:29 PM   #1198
Team Kwik's Avatar
I am not heading to Michigan so I should be there pending some other disaster.
When I do servo holes I like to just do it based on the car in my hand, when I take my time they come out pretty good. Chances are you are not going to want the servo in the same place as you had it on the old car, I would have to take a good look to be sure. Bruce will be away and he has that killer countersink bit, I need to find one of my own to have for just this situation!
The foam is never the same between Parma and Jaco, it's close though. Grey is pretty much the same, Magenta would be similar to a Jaco Single-Stage Double Pink. Since the attendance is up at RCE we should be able to maintain a groove week to week, if that happens we will most likely be running something more like Yellow/Purple 2-Stage.
Nick
Team Kwik
Old 03-01-2007, 08:06 AM   #1199
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
I see most have posted using the standard purple / gray Jaco combo for stock. I actually had problems with this combo the past few times out. I felt the purple fronts would get too gummy around 6-minutes and the car would oversteer and lap times drop signitficantly.
I switched to black / yellow Jaco combo and found this tire selection much better suited. The laps times were consistent the entire 8-minutes. Anyone have any thoughts on this?
I'm too lazy to try and run the Parma tires...as I'd have to re-shim the rear axle.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-01-2007, 09:07 AM   #1200
timmay70's Avatar
Dust from the dirt track has gotten onto the carpet track from floor sweeping, and attendance droped off a little between Dec and Jan. Where it is picking up now, I would expect the grip to continue to build from now till the regionals at RCE. Since this may be the case at our track, switching to the black/yellow combo may be the way to go. For now, I am thinking the purple/gray is the magic combo.
As far as Parmas go, the Magenta/Gray work great until traction builds, then switching the fronts to purples. I am very curious to try the new big rim Parmas. ymmv.
ROAR #105242
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
