Old 01-25-2007, 07:58 PM   #1111
beavis353's Avatar
Originally Posted by gotpez
I've never posted pictures before, hope I did this right!
Here are a couple of shots of mine. I put it in last weekend. A Novak GTB with a 13.5. I need to get some TQ drag wire to clean up some of the bulk of wiring, but no biggie.
The sensor wires are a bit too long, but I think with the TQ drag wire, it won't be too bad. Even as it sits, I didn't notice ANY tweaking from all that wire.
It may look ugly under the skin, but now that I've driven brushless, I never want to go back to brushed.
Nice looking car...
As soon as i get my brushless system installed, I will post a couple photo's. Heres a few things to remember when installing your brushless into your Speedmerchant...
The new 4.5 rear pod allows for a bit more space between the pod plates for the sensor wires etc. This is not necessary, but it does help.
The wires on a brushless are even more critical than standard speedo's, and 16 gauge should be used whenever possible. Tweeking can happen very easily.
Try running the sensor wire along the left hand of the car, and in through the side of the pod. This seperates it from the 3 power wires, and keeps them from hitting the body making your car tweek out.
beavis353 is offline   Reply With Quote
Old 01-25-2007, 08:16 PM   #1112
odpurple's Avatar
Originally Posted by beavis353
The most popular mehod of mounting the servo is flat to the chassis. Mount your servo with the right side of the servo touching the arm. This will allow the steering turnbuckles to be swept forward, providing the proper ackerman.
Also, the entire team is running the newest Kimbro large servo saver (dark grey color), and yes you do have to grind a bit of the chassis for it to fit properly. Go slow, and make sure you dont go all the way through the chassis.
I'm curious why you would run the large servo saver. Would you please explain and give us the Kimbrough part number? thanks
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 01-26-2007, 12:23 AM   #1113
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
Hi Od,
It's the same normal small Kimbrough servo saver, the change is in the servo. On my last car Bruce had me go flat to the chassis, literally nothing between the chassis and servo. If you don't grind out a portion of the chassis below the servo saver you can't get the servo all the way down. Most people seem to be moving to servos with flat ears so they are just bolted down without using mounts and of course no tape or adhesive is used so everything stays extremely low.
Nick
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 01-26-2007, 12:33 AM   #1114
odpurple's Avatar
Originally Posted by Team Kwik
Hi Od,
Nick
Thanks Nick,
That's what I thought. I use the kit mounts and cut them down so the servo is on the deck. A little grinding on the chassis does the trick to clear the servo saver.
Old 01-30-2007, 03:16 PM   #1115
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
I have read on this forum that you use a sae 82 deg countersink for the servo after drilling the hole .When I went to buy the countersink bit it was available in different sizes 1/2, 3/4, 5/8 does this size matter?
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 01-30-2007, 04:37 PM   #1116
protc3's Avatar
it doesnt matter.all that matters is that the cutting edge angle is 82 degrees.a smaller diameter would be preffered such as a 3/8
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-30-2007, 05:02 PM   #1117
Sal Amato's Avatar
Ok Thanks Jason
360 RC SPEEDWAY 2.0
Old 01-31-2007, 10:40 PM   #1118
RPage's Avatar
Flat servo mounting with no grinding needed. 2007 chassis design I just got from Bruce
RPage is offline   Reply With Quote
Old 01-31-2007, 10:56 PM   #1119
When can we order this new chassis?
gotpez is offline   Reply With Quote
Old 01-31-2007, 11:07 PM   #1120
RPage's Avatar
I ordered mine last week and got it today. Part # (smr 1418) stays the same. Even came with a little note saying that it was the 1st chassis with the new design
Old 02-01-2007, 02:27 AM   #1121
12thScaleCrazy's Avatar
That's a lot neater servo saver hole than the one I made with my Dremel. LOL.
12thScaleCrazy is offline   Reply With Quote
Old 02-02-2007, 12:54 PM   #1122
Trader Rating: 15 (100%+)
I need some setup advice.
I have 1.5 degrees camber in the front and the stock side springs. They are just touching (barely).
My problem is that the front tires wear uneven like I need less camber. Left and right wear the same but after one night with double pinks they are slightly tapered. Should I reduce camber or do I have another problem I am overseeing?
FT_TC3Racer is offline   Reply With Quote
Old 02-02-2007, 01:58 PM   #1123
Trader Rating: 8 (90%+)
Does your track have a lot of high speed corners or more slower corners?
Johnny Carey is offline   Reply With Quote
Old 02-02-2007, 01:58 PM   #1124
That was the exact same way i did mine.
Old 02-02-2007, 07:17 PM   #1125
Our track layout changes every week but our track is 48 x 100. I guess I would say it is pretty even mixed with high speed and low speed.
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
