Old 01-05-2007, 06:17 PM   #1081
Originally Posted by Carl Giordano
Anyone know if Bruce is away? I placed a small order from the speedmerchant on-line store about 2+ weeks ago and still no delivery?
thats odd.........
gotyournumber is offline   Reply With Quote
Old 01-13-2007, 09:01 PM   #1082
mikez's Avatar
Wow I cant believe this thread was on the 5th page.This thread should be top 5
at least.(on first page).I think the rev 4.5 is one of the best cars out there.
Who is running this car and why?Let's here your thoughts and share some set up's.The only thing I dont like (just nit picking) about the car is the old school front end.To get it right is a bitch.Please give some input on this subject.
Thanx Mike Malinconico.
mikez is offline   Reply With Quote
Old 01-14-2007, 08:30 PM   #1083
darnold's Avatar
I agree about this being a great car, that's why I consistently recommend it in my local racing circles.
Standard Mod setup seems to be: 20K diff lube in the tubes. White side springs with little or no pre-load. Blue or Red shock spring with pre-load set so that the car is flat or only .5 - 1 deg sag in the middle on the bottom side of the car when viewed from the side. 30-40 weight shock oil. 0.20 front springs. 4 degrees caster. -1.5 degrees camber.
Make sure the steering rods are angled like you see the team cars. Run magenta front and rear (also known as double pinks in some circles). I wish I had been running this earlier compared to my own setup but since Beavis got me dialed in at the end of the Halloween Classic I can truly say that this standard setup rocks!
darnold is offline   Reply With Quote
Old 01-14-2007, 08:39 PM   #1084
darnold's Avatar
There are some really good guys on this thread including Mike Dumas himself that know a LOT more about the car than I do and they are really helpful. That's one of the nice things about Team Speedmerchant. They really help.
Old 01-15-2007, 03:05 PM   #1085
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
For club racing with low to medium bite in stock I have been fiddling with:
20 Front Springs
Lowered Steering Blocks
2mm Castor Shims
Header Card Camber Shim
45wt Shock Oil
Blue Or Red Center Spring
About .5mm Droop
About 1mm Pod Sag
Blue Side Springs (New Style)
Ride Height 3.5mm all around
10k OFNA In The Tubes
Double Pink Jaco Wraps On All 4 Corners
Parma Speed 8 Body
Nick
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 01-15-2007, 04:11 PM   #1086
Trader Rating: 8 (90%+)
20 Front Springs
2mm Castor Shims
45wt Shock Oil
About .5mm Droop
About 1mm Pod Sag
Parma Speed 8 Body
Nick
Im running close to the same as Nick except:
40wt shock oil
Red Center Spring
1mm droop
.5mm Sag
CRC Blue Tube Lube
Parma Magenta Fronts
Parma Pink Rears
Thats what I run 19t with at Fastcats.
Johnny Carey is offline   Reply With Quote
Old 01-15-2007, 06:27 PM   #1087
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey guys, check out eBay auction# 110077978380 I posted my Rev 4.5 on there, absolutely the best of everything included!
Old 01-15-2007, 07:53 PM   #1088
mikez's Avatar
When you run header card camber shims are your axle's the same height?
It seam's the right side block has about 1 deg. camber on it's own.On the left side has 0 deg.When I shim to get 1 deg. camber on left side the axle height is way off.Does anyone have this problem?
Old 01-15-2007, 07:58 PM   #1089
eforer's Avatar
Send a message via AIM to eforer
The AE molds for the old skool arms are well, old. They are not really super consistent left to right. Pretty much do the best you can to make them even, if you have extras match them up as best you can.
Speed Merchant/Corally USA/Specialized RC/Team Kwik/Tekin/Sweep/Parma PSE/Team Pickles Performance
eforer is offline   Reply With Quote
Old 01-17-2007, 11:11 PM   #1090
Less than a day left on ebay... 110077978380 Check it out!
Old 01-18-2007, 05:36 AM   #1091
Thraex's Avatar
A while ago I heard that speedmerchant is working on a new front suspension.
Does someone know more about this? Because after that I never heard something of it again.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 01-18-2007, 07:37 AM   #1092
I was told in cleveland about it and that it was supposed to come out at snowbirds. the info is also given in the Indoor Champs write-up by him. It looked really good and consistent.
Old 01-18-2007, 03:12 PM   #1093
eforer's Avatar
The front end was tested by TJ and Dumas at the gate, then tj ran it at the champs. It is very promising even at this early stage. It allows for a much more slop free build then competing systems.
Old 01-18-2007, 03:30 PM   #1094
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Will it bolt directly to the exisiting chassis holes?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-18-2007, 05:05 PM   #1095
The way it looked on the car it did. But I dont know if it had a prototype chassis as well. The slop seemed almost non-existent, and the setup of it is not very intricute like most others. Will see.
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
