Old 10-23-2006, 02:48 PM   #931
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Originally Posted by Customworksking
tall order i know sorry like i said new to link cas...thanx I have everything but side springs and tube lube where is the best place to order the lube
You can get CRC lube from www.teamcrc.com. The 7000,10000, 30000, etc. you can get from Tower from any of the 1/8th scale offroad manufacturers (OFNA has a nice selection). http://www2.towerhobbies.com/cgi-bin...p?&C=CMH&V=OFN
-James
JamesArluck is offline   Reply With Quote
Old 10-23-2006, 03:01 PM   #932
eforer's Avatar
Send a message via AIM to eforer
ofna 10k silicone lube for 1/8th diffs is what you want. You should be able to buy it at your lhs.
Speed Merchant/Corally USA/Specialized RC/Team Kwik/Tekin/Sweep/Parma PSE/Team Pickles Performance
eforer is offline   Reply With Quote
Old 10-23-2006, 04:23 PM   #933
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default wire
looking for some 16 awg wire for my 1/12 where can i find some?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-23-2006, 04:25 PM   #934
http://www.robotmarketplace.com/marketplace_wire.html
-James
Old 10-23-2006, 07:06 PM   #935
www.tqracing.com has some very nice
wire for 12th scale. Alot of people in this
area use it .
He sold it for slot cars and now for rc cars.
Also the owner Ralph M is a hell of a nice guy!
Check it out.
giantbill is offline   Reply With Quote
Old 10-23-2006, 07:10 PM   #936
This area being New York . Ask around im
sure you can find someone who has used it.
Old 10-23-2006, 10:49 PM   #937
I use it too, it's the best wire currently available.
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 10-24-2006, 07:09 AM   #938
Lightbulb wire
the drag wire
Old 10-24-2006, 09:23 AM   #939
Originally Posted by eforer
Okay thats alot of questions:
Damper Tube Goo: 10k is fine for most things, 7k is also suitable. The heavy CRC damper fluid is good too.
Side Springs: That sort of depends on what tires you run. Typically the jaco guys run the .23 (white side springs) and us parma guys run .21 (blue side springs). Don't preload the side springs. The springs are progressive and pre-loading them changes their rate. Tighten them down till they just touch the link end. Tweaking the chassis is best accomplished with a pair of pennies on the front tires just aft of the axel. Lift the front end from the center slowly. Tighten the droop screw of the side that falls second, loosen the screw of the side that falls first.
Center Spring: You should have blue, red and gold. Copper and Black tend to be too stiff and silver is too soft. The jaco guys run mostly blue or red, for parmas usually red or gold (a little stiffer).
Center Shock Oil: The weight is less important than having the shock built well. 40wt is a good starting point.
Any other questions don't hesitate to ask.
wheres the droop screws ?
Old 10-24-2006, 10:20 AM   #940
odpurple's Avatar
the screws that hold the side springs
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 10-24-2006, 11:40 AM   #941
Default oic
thats i thought
Old 10-25-2006, 06:19 AM   #942
Mart42's Avatar
Hi guys,
I have a Speedmerchant Rev4.5 and a brand new 4.5 conversion in the for sale thread.
Take a look if you looking for one fast.
MARTIN LECUYER
Team Associated - Reedy - SMC - Team Scream - BSR - SlyGraphiX - Carpy's
[email protected]
Mart42 is offline   Reply With Quote
Old 10-25-2006, 01:47 PM   #943
eforer's Avatar
Are you inquiring about pod droop?
Pod droop is how far the rear pod hangs below the main chassis when the chassis is off the ground (ie you holding it up and looknig at it). It is adjusted by loosening or tightening the the center shock ball ends. When the center shock is longer, the pod hangs lower, more pod droop. Conversely, when the center shock is shorter, the pod doesn't hang as low, less pod droop.
Pod droop effects, pirmarily, the cars characteristics off power. The more pod droop, the more the car will transfer weight forward when you lift. Although it creates more on power steering it also tends to make the car a little mellower (more steering but less abrupt) as increased pod droop smoothly transfers the weight forward vs being abruptly interrupted by the center shock reaching its length limit.
Hope that helps.
Just to clarify on the links and end links. The link length is not a tuning option. The links are either right or wrong. Links can only be checked with the motor out of the car (and battery) and preferably with the side springs removed. If the links are correct, when you twist the pod on the pivot ball there should be even resistance throughout the pod's range of lateral motion. No high spots, no binding points etc. If there are, adjust links to compensate and try again.
The link ends are meant to pivot freely, but be firmly attached as to not detach in the event of an impact. The kit includes a small o-ring which is to be placed in the split in the link end with the screw passing through it. This prevents the link ends from becoming excessvely closed and binding on the pivot balls. They, like the links, are right or wrong and not a tuning aid.
Old 10-25-2006, 01:50 PM   #944
eforer's Avatar
also, those are not the droop scews, those are the tweak screws. There are no droop screws on a SpeedMerchant. See above.
Old 10-25-2006, 02:05 PM   #945
Ed,
They were asking you to clarify what you meant by "droop screw" in the quote above.
-James
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
