Old 10-18-2006, 09:04 AM   #871
Trader Rating: 15 (100%+)
Just got done putting my Rev 4.5 together and had a shock question. Is this the shock that everyone uses. It really seems cheap. I realize that it is not built by Speedmerchant but for the rest of the car to be so well built. I have never built a 1/12th scale before so I might be wrong.
I see CRC has a Dura-shock upgrade for this shock. What are you guys using for an upgrade or are you using this shock?
FT_TC3Racer is offline   Reply With Quote
Old 10-18-2006, 09:12 AM   #872
Where did you get your kit from i tried calling Speedmerchant and no answer left message and no reply is there other dealer that has this kit.
Mutabarucka is offline   Reply With Quote
Old 10-18-2006, 09:20 AM   #873
RichChang's Avatar
Not sure what shock you got with your kit, but I am going to assume it is the standard 1/12th shock. That design has been used for decades pretty much and it works fine, it is just a pain to build/maintain compared to newer versions of it (such as the CRC dura-shock).
I switched to the CRC dura-shock this season, but both are fine.
I've seen some folks use a touring car shock, but that seems a bit overkill to me.
-Rich
RichChang is offline   Reply With Quote
Old 10-18-2006, 09:38 AM   #874
Suspended
Trader Rating: 28 (100%+)
anyone have a good asphalt setup for the rev4.5?
racenut123 is offline   Reply With Quote
Old 10-18-2006, 09:40 AM   #875
TFR
TFR's Avatar
-Rich
Rich,
Isn't TC's shock has a bigger diameter cyclinder that it might hit the battery pack? Do I put spacers to lift the shock up? Would that affect the dampening of the shock?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 10-18-2006, 09:48 AM   #876
RichChang's Avatar
racenut123 - I think Larry Brown posted the set-up on Jeff's Rev.4 a few pages back. I'll try and find it for you. It is here.
TFR - amazingly, they had it cleared (as long as the batteries were in the back position and the shock body was located at the top shock mount). But, yeah, they had the ball stud at the bottom shock mount raised a bit to get clearance and yep, that affects steering (flatter shock increases on-power steering in general).
Not something I've tried nor do I see a need to try it. Most of the folks that I saw trying it have switched back to a regular shock.
-Rich
Old 10-18-2006, 10:14 AM   #877
Suspended
awsome.Thanks Rich!
Old 10-18-2006, 12:25 PM   #878
timmay70's Avatar
The shock included in the kit is the micro vcs shock from AE. The only pointers that I use when building it is to clean all the flashing off all the plastic parts carefully. Using a cotton end on a dremel, use some polishing compound on the inside of the shock body to remove all the milling groves and to make nice and smooth, being careful not to open up the inside diameter. Clean the body throughly of all polishing compound and left-overs. Before I install the volume compensating foam bit, I put some damping oil in the palm of my hand and squish the foam around in the oil. The attempt here is to try to get as much oil into the exposed cells in the foam, so that when I put it all in the shock and finish the build, as much of the air is eliminated as possible. Finish building as per the instructions. The result should be a nice smooth notchless shock.
I have two vcs shocks with different spring/oils built-up, along with a Silva shock. They all build pretty much the same. The advantage goes to the Silva shock if you are accident prone. The end on the shock shaft side threads into the body, pretty much eliminating the possibility of the guts popping out in a hard collision.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-18-2006, 05:52 PM   #879
CHRIS CHAVEZ's Avatar
Where can i buy the Silva shock?
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 10-18-2006, 05:55 PM   #880
rc_bam226's Avatar
Right here:
http://www.silvaconcepts.net/home.shtml
rc_bam226 is offline   Reply With Quote
Old 10-18-2006, 05:59 PM   #881
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
http://www.teamirsrc.com/silva.html
JamesArluck is offline   Reply With Quote
Old 10-18-2006, 06:05 PM   #882
15 bucks. Oh hell yea!
Thanks guys.
TQ RC Racing
Old 10-18-2006, 06:36 PM   #883
Customworksking's Avatar
Trader Rating: 73 (100%+)
Post rev 4.5
can someone tell me how to get a Fing refund from speedmerchant their sevice is crap as the saying go's tell 1 person you got a good car tell 10 when you don't! corally for me
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-18-2006, 06:42 PM   #884
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Just wondering if anyone has a different # than the one listed on the website for CS questions? I ordered a car on Friday and am just looking for tracking info. Thanks!
Old 10-18-2006, 06:54 PM   #885
Talking car
good luck I paid the 10 of Oct still no car or refund!
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
