Old 09-16-2006, 07:05 PM   #751
stormperson's Avatar
Send a message via AIM to stormperson
evil- sounds like your car is tweaked or you might have a collapsed front spring, something to make your car not have its weight even left and right.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 09-16-2006, 07:29 PM   #752
Trader Rating: 36 (100%+)
Yeah, that's what I thought. It's a brand new car, I went back and checked the front geometry and everything is good. Put the car on speedmind tweek board and it's good.
It only pulls during breaking. Running mod, it pulled just a tad on throttle but, breaking hard for a turn would make it pull the oposite way hard. I'm going to play with it a little more and see what I can find. I just didn't know if maybe someone had the same problem at one time. I'm used to driving T-bar cars and this is a little different than what I'm used to. I'll figure it out.
EVILGRAFX is offline   Reply With Quote
Old 09-16-2006, 07:43 PM   #753
Rob Phillips's Avatar
Was the car pushing and oversteering in the same corners consistantly? With the track just getting a new layout, it might be the way the carpet fibers are laying. I noticed a that in one corner my car would push a little and another that it wanted to oversteer. I ran the layout backward and it didn't have that push turning right that I had running forward. I have say, my car felt awesome. I don't know if I will even run TC again.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 09-16-2006, 07:59 PM   #754
You're right Rob, I didn't even consider the new layout but, I didn't notice any of that with my TC. Although, that was later in the day and it's a different animal all together. I got the batteries back in the car and am now thinking the wires may have been binding a little. Not totally sure about that but, I'm going to try wiring a little differently next time.
Later
Old 09-16-2006, 08:25 PM   #755
Still Bill's Avatar
Any ideas on a starting Stock setup to use on a Rev 4.5 for the IIC this coming week?
Basically, I have .020 front springs, blue center spring with 30 wt oil in shock, the new stiff SpeedMerchant rear springs and purple/gray CRC Procut Track Magnet tires.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-17-2006, 08:44 AM   #756
This is the set up I plan on running in vegas...
Front End:
.020 front springs
2 degrees of castor
a hint of toe in
Rear:
Blue center spring
.021 side springs (old blues)
10k diff oil in the tubes
30wt Xray in the center shock (40-45 of standard, AE, trinity, losi oil)
about 1 degree of droop and 1 degree of sag
Other:
-Parma purple fronts trued to 1.67 (make sure they dont wear too much or else you wont be able to pass tech. I run the lowered front steering blocks to be able to run a smaller tire)
-Parma grey rears trued to 1.72
-Parma speed 8 body
-around a 31-32/100 gear to start off with
and batteries full back and ride height as low as possible with passing tech
I have run pretty much exactly this set up minus maybe a center spring change (never softer than blue or harder than red though) and made 3 of the last 4 national level A mains that I have been to and the car has always been better than what my driving has shown, lol
If you have any questions at the race stop by me (Mark Strasnick), bruce or any of the speedmerchant drivers for help
Team Pickles
Old 09-17-2006, 09:01 AM   #757
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Hi all,
I am thinking of getting one of these cars and just wanted to know a few things first:
1. How do they perform on asphalt? (med-high bite outdoor tracks)
2. What do I need to buy to run on asphalt?
3. What spare/optional parts will I need?
4. What is the quality of the kit like? (ie. how much handfitting, missing/incorrect screws, etc. etc.)
Thanks in advance.
Leonard.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 09-17-2006, 05:38 PM   #758
Leonard,
See page 22 of this thread for the setup I posted a few months ago. My son Jeff Brown used this setup to win the US Asphalt On-Road National Championship in the stock class. This setup works very well in stock and 19 turn racing...modified may need a little different setup due to extra power.
The only extras you should need are .018 front springs and the Jaco tires mentioned in the setup. Other tires may work, but this is what Jeff used. Kit quality is excellent...no Dremel tool needed.
Larry Brown
Larry Brown is offline   Reply With Quote
Old 09-17-2006, 06:34 PM   #759
Has any tried the newer AE front end on the car on carpet ? If so how do you like it ?
John Q is offline   Reply With Quote
Old 09-17-2006, 06:35 PM   #760
Later
Yeah, when I got there traction was much higher than it was Friday evening when I ran. Try running it backward through the sections that were giving you problems, and don't forget TC are 4wd, so they may not feel it as much. Try the Dumas setup out, or you can run mine and see what you think. I'll let you bind your radio to it so the radio will feel more natural and then you can feel the setup. As for the wiring, I have some 16awg if you need some, that's what I used.
Old 09-18-2006, 03:17 AM   #761
Originally Posted by Larry Brown
Leonard,
Larry Brown
Thanks heaps Larry. Info much appreciated.
Leonard.
Old 09-30-2006, 10:39 PM   #762
Well, I am back from one of the greatest races hosted by Scotty E. in Las Vegas, the International .Indoor .Championships. With over 550 entries and world class drivers from all around the world it makes it one of the most prestegious and largest on-road races in the world. My hats off to Scotty and the crew at the I.I.C, as they did an excellent job. The hotel was first class with plenty of entertainment so you or your significant other wouldn't have to leave the hotel for extra activities. It is just an awsome race... I am already looking forward to next year event.
The I.I.C. turned out to be a great race for Team Speedmerchant. In the Modified 1/12th scale division Speedmerchant TQ'ed and Won the Event. Yet another great accomplishment for Team Speedmerchant with the REV 4.5. The car was awsome from the first Brood Powered battery to the last of the event.
I would like to personally thank all my sponsors, Team Speedmerchant, Team Brood, Team JR radios, team Novak and many more for all the help at the race. Bruce Carbone is an excellent person not to mention not a half bad mechanic... LOL, Just kidding. I must say Bruce and myself make a good team along with Jake Pritchard, Barry Baker, Andrew Gray and many others that I might have left off.
Couldn't do it without you Bruce, good job man....
Mike Dumas is offline   Reply With Quote
Old 09-30-2006, 11:00 PM   #763
whats the best way to tighten up the suspension link balls without marring them?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 10-01-2006, 12:16 AM   #764
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
Hi Smojoe,
When I see mine getting a little loose what I like to do is take a nice pair of pliers and with the link attached use it to clamp down on the ball while I tighten the screw. If you are careful about it you won't crush the plastic rod end and those balls won't come loose again.
Nick
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 10-01-2006, 12:21 AM   #765
Team Kwik's Avatar
Congratulations again Mike, you drove just perfect as usual. The field in Vegas was pretty rough and you almost made it look easy, tone to tone.
I just wandered over to the Speedmerchant site and Bruce put up a little race report from Vegas. Along with Mike's TQ and win in mod there were two Rev 4.5's in the stock main and with the traction challenges at this event the Rev 4.5 really showed how well it can be adapted in a hurry!
Check it out:
http://www.teamspeedmerchant.com/Vegas2006.html
Nick
Team Kwik
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
