Old 06-14-2006, 07:16 PM   #661
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
Hi Guys,
I had a chance to run my Rev4.5 last night for the first time and I have to say, this is hands down the most amazing car on the market right now. Those of you who know me will agree that I am by no means an incredible wheel but last night I looked like a million bucks! I attached a few pictures of the car for you guys to check out and there's a bunch of little updates over the past year or so that really complement the kit. Bruce deserves a big pat on the back for taking an already proven winner and refining it to be an even better chassis.
First on my car is obviously the 4.5 conversion, the pod went together smoothly and the parts fit well. Overall it's the best innovation yet for the Rev.4. No more struggling to change motors and out of every 4-bolt pod design this one is by far the easiest to solder a motor into. Worth every penny!
Next is the rear tweak brace and large standoffs. I had purchased a kit some time ago and it included the standard tweak brace made of the same thickness carbon as the chassis. Bruce and company saw this part could exhibit flex and over time might be an area of concern. After talking to Bruce he mentioned the updated part which is made of a much thicker carbon so of course I jumped at the idea. Also on my car are the new large standoffs, talk about a SOLID rear end, the added size not only looks cool but it does lend extra support to this critical area of the chassis. If you've got an older car treat yourself with this setup, it's pretty cheap and worth it on the track.
Finally I got a bunch of the new tweak springs. Bruce wasn't kidding when he said these were more consistent and much higher in quality. From the moment you snap these on the retainer you can see the difference and they hang nearly perfect. Toss out the old painted springs and snag a few pairs of these as they are totally worth it.
Sorry for rambling on, but these tweaks all added up to some great runs for me last night at the local track. I went A LAP faster than my best after taking my time freshening the car up with a few new parts!
Nick
Speedmerchant Rev.4-nicksrev4.jpg   Speedmerchant Rev.4-nicksrev4-1.jpg   Speedmerchant Rev.4-nicksrev4-2.jpg
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 06-14-2006, 09:40 PM   #662
Team kwik where did you order you parts from?
kmorast is offline   Reply With Quote
Old 06-14-2006, 09:49 PM   #663
Team Kwik's Avatar
Direct from Speedmerchant!
http://www.teamspeedmerchant.com
Nick
Team Kwik
Old 06-14-2006, 11:16 PM   #664
Jeff Brown's Avatar
Originally Posted by Larry Brown
kmorast- Try this on the Rev. 4:
Jaco pink rear, double pink front tires
.018 front springs
4-6 degrees of caster
1 1/2 to 2 degrees of camber
silver center spring, 25 wt. shock oil
new high quality side springs from Speedmerchant, rate close to blue springs
5mm ride height F&R (lower if traction is really high)
1/2 to 1 mm sag at rear of main chassis when race ready
approx. 1 to 1 1/2 degree droop on rear pod at full shock extension
Should be really good
This is my setup from the Nationals this past week...... obviously that is my Dad posting.
I ran Trinity Red Dot with SXT 2.0 sauce on top. Soaked for about 30 minutes and wiped off. Stuck like velcro. This combination of sauces was good for about 2 tenths a lap faster.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 06-14-2006, 11:27 PM   #665
odpurple's Avatar
Jeff
Jeff,
Thanks for the sauce help at the Nats with EJ's car. I can vouch for it being the hot setup. Congratulations on the win, you were in a league of your own all week!
O'D
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 06-15-2006, 12:00 AM   #666
Ike
Ike's Avatar
Any chance the car will be offered with the updates included in the kit?
Ike is offline   Reply With Quote
Old 06-15-2006, 10:44 AM   #667
JayBee's Avatar
Trader Rating: 31 (100%+)
That's what I wanna know
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-15-2006, 02:53 PM   #668
Team Kwik's Avatar
Hi Guys,
I just talked to Bruce about this and there will be a full 4.5 kit some time mid summer. All these parts seem more like running changes, for instance the updated thick tweak brace has been included with the kit since around February. Just takes a little while to get things worked in.
In the meanwhile the conversion is there (that's what I picked up) so you don't really have to wait if you have to have it now (that's me).
Nick
Team Kwik
Old 06-15-2006, 03:23 PM   #669
JayBee's Avatar
Thanks Nick
Old 06-15-2006, 06:40 PM   #670
Jeff Brown's Avatar
My dad forgot to mention 5,000wt OFNA diff lube in the dampner tubes.
Jeff
Old 07-01-2006, 02:20 PM   #671
Trader Rating: 62 (100%+)
Nick
I ordered a Rev 4 + parts direct from them back on 6-13 and have yet to see it.
Hows that for customer satisfaction.
The Wease is offline   Reply With Quote
Old 07-01-2006, 03:01 PM   #672
Team Kwik's Avatar
Hi Wease,
I don't know if Bruce made any announcements but he is currently in Italy supporting his team at the worlds. Not sure when they return but he will get you taken care of as quickly as possible i'm sure.
Nick
Team Kwik
Old 07-01-2006, 03:12 PM   #673
Trader Rating: 36 (100%+)
this is from the Speedmerchant home page
"The SpeedMerchant crew leaves for the On-Road World Championships in Turin, Italy. We'll be out of the office from Monday June 26th to Wednesday July 12th. All orders placed during that period will be processed on the 13th and go out shortly afterwards. Thank you for being patient. Between the outstanding sales of the Rev 4.5 conversions, and the preparation for the World Championships, we are really struggling to keep up with the shear ammount of orders. All back orders (National & International) either went out today or will go out immediately upon our return home. Have a great week.-Bruce"
EVILGRAFX is offline   Reply With Quote
Old 07-01-2006, 03:17 PM   #674
I talked to him last Friday and he stated and I quote " I will mail it out Monday priority mail and you'll have it Wednesday." and obviously I haven't received it. I'm sure it will be taken care of when he gets back.
Old 07-01-2006, 03:20 PM   #675
Whats that have to do with the order I placed on the 13th of june
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
