Old 05-21-2006, 04:54 PM   #646
odpurple's Avatar
Originally Posted by reynard55
I have the new hollow aerial mast to fit to my car, should I run the aerial wire up the centre or wrap it round the outside?
I think that up the middle would look much better but I worry that it will snap the wire if the mast breaks.
I suppose it is possible that the antenna wire could be damaged when the roll over breaks, but I ran the wire inside the hollow Paragon Pro Stick antenna for years and never had that happen when I broke one.
odpurple is offline   Reply With Quote
Old 06-08-2006, 01:27 PM   #647
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
Default Rev 4.5 Conversion
Hi Guys,
I just got a peek at this from Bruce at Speedmerchant and I must say it looks very very slick. Though it may look like just a 4-bolt pod conversion it's got a bunch of new and well thought out features. No more removing the top plate to swap motors, the top plate is machined in so the motor screw washer doesn't rub, motor offset has been adjusted for today's technology and a nice centerline mark for setting rear track width. Best of all the suspension geometry hasn't changed one bit!
Mine are on the way already, snag em' while you can!
http://www.teamspeedmerchant.com/Rev45Conversion.html
Nick
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 06-08-2006, 03:51 PM   #648
CypressMidWest's Avatar
yup,
The 4.5 edition rear pod looks AWESOME. Plenty of room for brushless, and soldering Orion or Checkpoint endbells. Same geometry, so you know it'll still be the best handling 12th scaler on the market, but now even easier to use.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 06-10-2006, 03:44 PM   #649
Team Kwik's Avatar
The best just keeps getting better!
The round 3 sheet was just posted for the paved nats with Jeff Brown putting down the TQ for Speedmerchant. Jeff is really showing what the Rev.4 can do on asphalt, he just keeps getting faster and faster!
I will certainly post some pictures of my ride with the new Rev 4.5 pod installed, if you haven't snagged one yet guys don't hesitate! This is without a doubt going to be the hot setup.
Nick
Team Kwik
Old 06-10-2006, 07:43 PM   #650
Anybody have a good starting set-up for smooth high traction indoor asphalt? I will definately need to know springs and tires that work best.
kmorast is offline   Reply With Quote
Old 06-10-2006, 08:57 PM   #651
kmorast- Try this on the Rev. 4:
Jaco pink rear, double pink front tires
.018 front springs
4-6 degrees of caster
1 1/2 to 2 degrees of camber
silver center spring, 25 wt. shock oil
new high quality side springs from Speedmerchant, rate close to blue springs
5mm ride height F&R (lower if traction is really high)
1/2 to 1 mm sag at rear of main chassis when race ready
approx. 1 to 1 1/2 degree droop on rear pod at full shock extension
Should be really good
Larry Brown is offline   Reply With Quote
Old 06-10-2006, 08:59 PM   #652
Taz_S's Avatar
.018 front springs
great going larry on you weekend so far and the SM4 looking good. any thing new on it?
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 06-10-2006, 09:05 PM   #653
Stock Rev 4, except the front end is the new style (no reactive caster) instead of the "old skool"- geometry is almost identical between the two. It's easier to adjust caster and camber with the new style, is all.
Old 06-10-2006, 09:29 PM   #654
Team Kwik's Avatar
Hi Larry ::wave::
That setup is where it's at for the Rev.4, no two ways about it! I know Shawn set his car up nearly identical for the paved nats and this being his first time on asphalt his exact words were "Feels almost the same as carpet"!! If not for serious traffic troubles in round 4 he might have been in the show as well.
Nick
Team Kwik
Old 06-10-2006, 10:57 PM   #655
Larry thanks I will give it a try; sounds like a good starting point. Hopefully I can drive a 12th on asphalt since I've only run carpet. I'm in Japan and from what I've seen they can really tear the track up with their 12th scales.
Old 06-10-2006, 11:47 PM   #656
chris_morrison_'s Avatar
i have just started to race my 12th scale out door I'm using the same setup as i us indoor with traction compound ad the car is dialed.
chris_morrison_ is offline   Reply With Quote
Old 06-11-2006, 06:52 AM   #657
Hi Nick
Shawn didn't do too shabby for his first asphalt race And his motor tuning skills are obvious. Hope Team Kwik is off to a great start.
BTW, I saw your post on rclive earlier this week, but the darn thing wouldn't let me chat- tried several times
Larry
Old 06-11-2006, 12:10 PM   #658
I'm pretty sure I'm going to get a rev.4 (first 1:12 so bear with me ) when a friend next goes to the us. What parts am I going to need for tuning this kit? I'm going to be racing on a smallish indoor carpet track. I'm guessing some different rear tweak springs are a good idea, and ive got plenty of shock oils already. Do AE rear shock springs fit? I take it the rear axle is a standard 1:12 part? It's the only part I can really imagine breaking and I can probably only get AE/Corally/CRC ones in England.
Is there anything else that I need to get the car handling well? I'm not intending to get every small option part available anyway, so long as the car is quick around the track.
Thanks,
Ralph
ralph_c is offline   Reply With Quote
Old 06-12-2006, 03:05 PM   #659
odpurple's Avatar
Thanks,
Ralph
You will probably only need the two new tweak springs (.021" and .023", I think) and some AE shock springs (blue and red). The rear axle is an IRS unit, same as for the L4. Get some AE front springs also, .020 and .022.
Old 06-12-2006, 03:07 PM   #660
Cheers
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
