Old 02-19-2006, 09:19 AM   #526
stormperson's Avatar
Send a message via AIM to stormperson
My $.02 about tires on the rev. 4...
In stock at least...
I have always run (on every track) grey's and purple (parma tires) and been very happy with them, I have tried pink rear's however they just dont feel the same, and arent as fast. Grey's do wear alot more than pinks, espically on lower bite club racing tracks, thus making pinks a decent alternitive to grey's for club racing.
As far as the servo, I like to drill holes just incase the shoe goo breaks or something and I have a qual up and I dont have time for it to dry. But many races do just shoe goo in their servo (make sure its perfectly true when you place it though)
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 02-20-2006, 11:04 AM   #527
darnold's Avatar
Hey Timmy, how are things going? Good job at the Birds dude.
I think I see your point..a little confusing
What I was trying to do is give both sides of the picture.
People normally say that Pinks on Carpet don't give as much side bite as Grays thus the rear end is more hooked up with Grays on Carpet even though it's usually said that Pinks give a little more forward bite on Carpet for a little more rip off the corners. However on Asphalt due to their different type of foam Pinks will actually heat up and get sticky and thus give more side bite than a Gray in that circumstance. That's why people who race Ashpalt will usually say that Pinks are the way to go instead of Grays but people who race Carpet will say that Grays give more bite.
Regarding the wear issue; Grays on a lower bite Carpet track can wear so fast in a modified run that you wind up running on foam that no longer has Paragon on it which we normally refer to as "blowing" the traction out of the tires and people use to see this a lot with Whites. Since Pinks wear less this effect of "blowing" traction out of the tire may not happen as easily. On Carpet I normally don't experience blowing the traction out with Grays and I agree with Stormperson that I typically like Grays on the rear of my Rev. 4 better than Pinks. I can do with both, the Grays just feel a little better and more consistent on Carpet for this car IMHO. I hope this makes sense now...
darnold is offline   Reply With Quote
Old 02-21-2006, 04:39 PM   #528
Default Rev 4 tweak plate
In the Rev 4 kit the new tweak plate is a bit thicker than original one - does anyone have any experience with the new as oppsoed to the original and why it was upgraded?
DLM2005 is offline   Reply With Quote
Old 02-21-2006, 05:07 PM   #529
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
On the Rev.3 the tweek plate attached to the chassis much closer to the tweek springs, giving it more support. After moving the supports towards the center of the car, it made the tweek plate flex more. Going to thicker graphite lessens the flex and allows the tweek springs to do their job more consistantly.
-James
JamesArluck is offline   Reply With Quote
Old 02-23-2006, 05:59 AM   #530
I ordered some stuff off Bruce via the online shop at the start of Feb.
a delay was expected due to the snowbirds but i still have had no response.
I need it shipping to the UK so I was expecting an email with the extra shipping costs. I have emailed Bruce again but have had no response, Is this usual for Bruce? What is the best way of contacting him?
reynard55 is online now   Reply With Quote
Old 02-23-2006, 06:15 AM   #531
Reynard- I wouldnt worry about it, I just talked to bruce last night and he said he was about to ship out a bunch of backorders today and tommorow. He is still catching up from snowbirds.
Team Pickles
Old 02-23-2006, 08:24 AM   #532
-James
I just put the new tweak plate on - major improvement - and just ordered the new tweak springs.........by the way what was the cause of the radio interference that Dumas had at the 'Birds?
Old 02-23-2006, 10:32 AM   #533
CypressMidWest's Avatar
Hey all you Speedmerchant faithful!!! The news section on the website has been updated, and the new tweak springs and decals are available from the online store. Check it out.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-23-2006, 10:49 AM   #534
Is Bruce coming to the carpet nats? I didn't see his name on the entry list.
-James
Old 02-23-2006, 01:46 PM   #535
-James
I would assume so, he may be going just as "team manager" though.
Old 02-23-2006, 01:49 PM   #536
Cpress ..... this is Ruben from Stockton RC Raceway. If you know how to get a hold of Bruce by any other means than the numbers posted on the Speedmerchant website please emil me at [email protected] I really need to speak to him.
schurcr is offline   Reply With Quote
Old 02-23-2006, 05:06 PM   #537
Ruben, I'll see what I can do. I know he's been SWAMPED since he got back from the snowbirds. this is Ian I am posting under Loren,
llamont is offline   Reply With Quote
Old 03-04-2006, 12:33 PM   #538
Anyone know just how swamped he is?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 03-05-2006, 09:47 PM   #539
BritRacer's Avatar
ok i am having real glitching troubles.
lrp q2
futaba 3002 servo
ko 302f 75mhz
Helios
-Running a cap on the receiver.
-Receiver is mounted on dbl tape/lexan/dbl tape
-changed crystals 4 times
-put receiver on it side
-swapped esc and receiver locations
-antenna wire running straight up and down
-TX voltage 10.4v
Any other ideas??
BritRacer is offline   Reply With Quote
Old 03-05-2006, 10:14 PM   #540
Scrad's Avatar
Trader Rating: 15 (100%+)
Try putting a diode on the motor. Sometimes the built-in ones go bad. I had this happen on a monster stock, put a diode on and all was good.
Scrad is offline   Reply With Quote
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
