Old 02-02-2006, 09:43 PM   #511
Jeff Brown's Avatar
Originally Posted by Crashby
$6.95 is the base, lowest shipping costs right now with the USPS.
No it's not. It costs $4.05 to ship USPS for 2-3 day delivery in the US.
Looking to see Dumas lay it down again in 12th Mod. Now, if I can prevent glitching I might go somewhere at this race........ although my Aerial 360 Gainer to perfect landing in Cleveland was nice.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 02-02-2006, 09:54 PM   #512
odpurple's Avatar
Originally Posted by crimson eagle
Reminds me - OD i have a piece in my toolbox for you to wiegh. Chris
OK, I'll weigh it but my scale only goes just so high
odpurple is offline   Reply With Quote
Old 02-02-2006, 10:17 PM   #513
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Maybe you could put it on some sort of platform?
I was thinking..... Maybe you could change your name to....
IDpurple?
What do you think?
crimson eagle is offline   Reply With Quote
Old 02-02-2006, 11:27 PM   #514
I aint changing it, I like it too much.
Mad Dogs and Englishmen!!!
Crashby is offline   Reply With Quote
Old 02-03-2006, 12:00 AM   #515
Nick-C's Avatar
Jeff
SAW IT IN PERSON! From here on out it shall be known as the "Brown Round" =)
It was a very close second to what I am now calling the "Dumas Departure", it's not every day you see a 12th scale car just peel off the track like a hydroplane boat. Luckily there were zero casualties.
Good luck to tall the Speedmerchant guys heading to the Birds next week!
Nick-C is offline   Reply With Quote
Old 02-06-2006, 09:50 AM   #516
Ok, Mo Denton just laid down a new track record at Y-City (Zanesville, Ohio) I checked out his set up:
red shock spring - oil ??
white side springs
mostly a newly built stock Rev 4
Front tires - Parma Violet (dual compound)
Rear tires - Parma Gray
Speed 8 body
Question: Info on the Parma Violets - I can't find them anywhere.
The track was a very technical - med grip/non Paragon track. His car was perfect. most everybody else was using purple fronts and gray rears.
I did notice also he ca'd the sides of his tires.(what type of ca I don't know)
DLM2005 is offline   Reply With Quote
Old 02-06-2006, 11:13 AM   #517
stormperson's Avatar
Send a message via AIM to stormperson
Depending on the traction I normaly just use magentas or purples in the front, violets i am pretty sure are a dual compound sorta like a plaid or cyan. If you cant get enough steering with purples i would normally just go to magentas or dependin the layout softer front springs or stiffer rear. Generally for all club races I run magenta fronts though.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 02-06-2006, 11:41 AM   #518
Violets are a dual compound. The inner half of the tire is magenta and the outer half is purple. It's similar to the TC tires only there's more than a thin ring of harder foam on the outer edge of the rim.
brianrice is offline   Reply With Quote
Old 02-06-2006, 12:22 PM   #519
Three more questions:
1)What is the difference between Parma Grays and Pinks - They are both rated 30
2)BSR rates their XXpink at 35-40. Would that be close to Parma Magenta.
3)BSR Pinks are rated at 30-35. Would that be close to the Parma Gray and Pink?
Old 02-18-2006, 12:28 PM   #520
ttt
kmorast is offline   Reply With Quote
Old 02-18-2006, 12:33 PM   #521
Korey Harbke's Avatar
Greys and pinks may have similar durometer ratings but their foam is different. The Grey produces a little less traction but wears faster. The Pinks produce more traction, they tend to hold traction longer, and dont wear quite as fast.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-18-2006, 01:23 PM   #522
I need some parts for my Rev4. I have tried the web site but the parts I need aren't listed, I have also tried Hobby Ect. I need a crossbrace that mounts the damper tubes and body mounts and I would like to get a set of damper tubes. I am in central Ohio.
Thanks, Craig Thompson
[email protected]
740-973-5069
RCRacer6 is offline   Reply With Quote
Old 02-18-2006, 06:43 PM   #523
darnold's Avatar
It is generally agreed that on carpet Grays produce more side bite than Pinks but that Pinks produce more forward bite (although on asphalt Pinks tend to produce more side bite because their traction comes more from friction than the traction compond in the carpet) and that due to the lower wear rate of the Pinks they can hold the traction that they have longer....but...usually on carpet Grays will hold their side bite longer than Pinks even with the increased wear rate...
darnold is offline   Reply With Quote
Old 02-18-2006, 11:24 PM   #524
Timmy Heiser's Avatar
huh
Timmy Heiser is offline   Reply With Quote
Old 02-19-2006, 12:17 AM   #525
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i had a question... do most of you guys running the Rev4 drill for servo mounts, or just shoegoo it straight down? just reassembled mine after updating from the 3 to the 4, and wasnt sure which would be the best....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
