Old 12-11-2005, 12:22 PM   #361
Originally Posted by TJ Bradley
Colts and Giants teaser. speedmerchant lock of the week.
Those are the given. The money makers are Stealers/Bears and Packers/Lions.
Brian Anthony is offline   Reply With Quote
Old 12-11-2005, 12:38 PM   #362
Originally Posted by crimson eagle
A few of us on Wednesday evening at Stockton ran the setup with the tweak screws backed off on our Rev 4's in stock. I like this a lot it felt like the car was a lot less nervous and the rear of the car was felt more bolted down. I compensated but running max caster (new style front end) and more traction compound on the front. Car was great, a lap improvement for the race and .4 sec improvement for a lap. This wasn't all down to the side springs though, I worked on the front end of the car which helped a lot. Have any of you tried this yet with any success?
I read through Bruce's info from the recent race and I have to echo a lot of what he said, I thought it was easier to drive fast (yes I know it's a relative thing in stock).
Chris
Chris,
What 'new' front end? No more 'old skool' front end? or just a modded version of it?
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 12-11-2005, 03:36 PM   #363
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Originally Posted by NitroHead
Chris,
I have 2 rev 4's, one with he old skool front end which ironically is my newest car and one with the newer associated style front end. I have only used the old skool version a couple of times but I like the newer one as it is a bit more adjustable but i do agree as Bruce mentions that the new front end can get very sloppy in a big hurry. I am working on that though, maybe I'll have something interesting in a few weeks.
The car is great, James Arluck and I had a great final yesterday, he got me by .157 of a second and we both turned some great laps. You know you have driven hard when your 3700's don't have enough left to register on a discharge after a STOCK race.
The old skool car I have will probably become a 19T car with a prototype front end.
Chris
crimson eagle is offline   Reply With Quote
Old 12-11-2005, 06:53 PM   #364
TJ Bradley's Avatar
Stealers for sure. packers/lions...scary
TJ Bradley is offline   Reply With Quote
Old 12-12-2005, 10:06 AM   #365
Cool, thanks Chris.
Old 12-12-2005, 10:18 AM   #366
mtveten's Avatar
Trader Rating: 27 (100%+)
Anybody know where I can order a Rev.4 that offer 2 or 3 day shipping?
Mark
mtveten is offline   Reply With Quote
Old 12-12-2005, 10:29 AM   #367
CypressMidWest's Avatar
Mark
Try www.Hobbyetc.com
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-12-2005, 10:35 AM   #368
mtveten's Avatar
Hobbyetc is all out, any other suggestions?
BTW how small of a front can you run with the "OLD SKOOL" front end? Will I need to mill down the front arms so I can use 40mm wheels in the front?
Mark?
Old 12-12-2005, 10:53 AM   #369
mtveten's Avatar
WooHoo found 1, Superior hobbies had 1 left but boy did they gouge me on shipping.
What spares should I stock for the car and if anyone has a good base setup for high bite asphalt that would be greate.
Mark
Old 12-12-2005, 11:12 AM   #370
Mark?
Mill down your steering blocks and you'll be able to run tires that small. Bruce should have a tutorial for this procedure on the Speedmerchant site fairly shortly.
Old 12-12-2005, 11:19 AM   #371
mtveten's Avatar
Wouldn't milling the steering knuckle also effect the load on the front springs? What is the reason you dont mill the block front arm like IRS does with their modded new ASC arms?
Mark
Old 12-12-2005, 11:27 AM   #372
Mark
You do actually shim the spring to take up the slack the milling creates.
Lowering the whole arm significantly alters the roll-center of the cars front-end and that leads to all sorts of other issues.
Old 12-12-2005, 11:37 AM   #373
mtveten's Avatar
So if milling the block arms causes problems would I be correct in assuming that I should shim the steering block and not under the arm to adjust for larger size wheels?
Mark
Old 12-12-2005, 11:50 AM   #374
Mark
Once you've milled the steering blocks, that's correct. If you haven't milled the steering blocks, you're kinda stuck raising the whole arm.
Old 12-12-2005, 12:00 PM   #375
Mark?
Yes. You will need to either mill down the arms or the steering blocks to run small diameter tires. Anything below 43mm starts to get you under the 3mm ride hight rule.
Crashby is offline   Reply With Quote
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
