Old 08-06-2005, 11:52 AM   #151
CypressMidWest's Avatar
Originally Posted by Mabuchi540
any tips/tricks for getting perfect alignment to drill the servo mounting holes?
And a few quick questions.....
The above mentioned holes require a 3/8th drill bit right? Although this is not the size mentioned to get at the front of the instructions, so back to the hardware store is it? lol
Did your Rev4 kit come with body clips (mine didn't) but the instructions show that some are there (step 22)?
What size nut driver would I need for the diff nut? The bag doesn't state what size it is (it looks like a wheel nut of an old RC10).
Thanks in advance.
Many of the team drivers shoe-goo (silicone adhesive) their servos in. This is what I do, as I feel it is a more secure way of mounting the servo, and it's significantly lighter.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 08-06-2005, 12:08 PM   #152
I agree - use shoo glue for the servo - less weight - can align perfectly - mine has been on there for a year that way
DLM2005 is offline   Reply With Quote
Old 08-09-2005, 06:52 PM   #153
darnold's Avatar
Ian or anyone else- Do you know if anyone races the Rev.4 over in Japan or if there is a team like CRC has?
darnold is offline   Reply With Quote
Old 08-10-2005, 12:01 PM   #154
Not that I know of Dave.
Old 08-10-2005, 12:06 PM   #155
Can the servo and goo be removed from the chassis if need be?
Andy
adavid is offline   Reply With Quote
Old 08-10-2005, 12:15 PM   #156
RJonesJr's Avatar
Send a message via AIM to RJonesJr
yea it can be removed as long as you use "Shoo goo" not the cheap stuff.
RJonesJr is offline   Reply With Quote
Old 08-10-2005, 12:26 PM   #157
Cool. Thanks for the reply.
Andy
Old 08-10-2005, 12:38 PM   #158
darnold's Avatar
Man it would really be nice if Bruce would contact someone via the kimihiko-yano.net site so that the Rev.4 would really become known over there (hint, hint).
That web site is pretty cool and the guy behind it is a part of Rc Tech i do believe.
BTW, i read that the Gate may hold a Roar carpet regionals this year, have you heard anything Ian or any one else?
Old 08-10-2005, 02:11 PM   #159
Not really, I'm sorta outta the loop these days.
Old 08-10-2005, 03:29 PM   #160
robk's Avatar
Trader Rating: 22 (100%+)
For a second there I thought darnold was gonna become #1-driver san in Japan...
Old 08-11-2005, 06:40 PM   #161
darnold's Avatar
-Robk, domo arigoto
racing some for ready am I. Actually i honestly wish i knew Japanese and Chinesee as i think those two languages are really cool.
Old 08-13-2005, 03:56 AM   #162
Quick question.....
I'll be starting construction (finally ) tomorrow. Just wondering what's a good/average/typical/whatever starting weight of oil for the Micro shock and side damper tubes and also the shock spring?
I have 7000 or 10,000 weight to use for the side tubes and pretty much any weight oil you might mention for the shock. As for the springs I have a silver, green or red to choose from.
Almost forgot.....this is for a high grip asphalt technical track with purple fronts and pink rears (and starting off with either a stock or 19 turn motor).
Thanks in advance.
Mabuchi540 is offline   Reply With Quote
Old 08-13-2005, 03:45 PM   #163
jland's Avatar
Trader Rating: 74 (100%+)
Mabuchi540,
just got my REV4 on the track for the first time this week. I put 25wt oil in the shock, silver spring, 7000wt in damper tubes. I was also running purple and pink tires...Very good handling right out of the box, was very impressed. Just give it a go, and work from there....
jland is offline   Reply With Quote
Old 08-13-2005, 06:57 PM   #164
Were you runnong on asphalt? And what front end did you use?
Old 08-15-2005, 05:44 AM   #165
Did anyone else notice while building their Rev4.....
that the left side suspension block had a lot of flash on it and doesn't "appear" to be molded as well as the right side?
I had a look at the couple of spares I've got and it's the same with them (right side is better and the left has all the mold flashing).
Anyway the reason I bring it up is because the left side steering knuckle sits lower as a result (ok so it's only like 1/4 of a mm and there is no spring free play) but I'm wondering if this would cause problems when the car is going?
My assumption is no, because under load both knuckles are "floating" anyway but that the lower one might bottom out sooner?
Just a guess, I hope all that makes sense but as it's my first encounter with 1/12th suspension I may be way off lol.
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
