Monster Stock Question >
Old 08-25-2004, 04:11 PM
Default Monster Stock Question
Hi All,
I've read through the stock motor thread and got some Putnam brushes and springs. I read about the Green/Blue brush combination for the Monster stock. I also have the red and green springs and am not sure which I should use since most people only talked about the brushes so I am looking for your recommendations on the spring combo. Thanks!
HauntedMyst is offline
Old 08-25-2004, 04:36 PM
StephenSobottka's Avatar
hey haunted, long time no see.
On my monster stocks I have never run the putnam brushes, just the 767 or 4505. I usually run reds on both sides with 4505. The 767 are good for the initial first part of a run but fall off. Use the highest silver putnam brush. It will end up being very close.
StephenSobottka is offline
Old 08-25-2004, 05:37 PM
Default stock springs
just use the stock springs with the highest silver content brush from atlas in a waffle pattern this is good for all round power with a tad more top speed
pink panther is offline
Old 08-25-2004, 06:09 PM
danjoy25's Avatar
Trader Rating: 38 (100%+)
Default Re: Monster Stock Question
Originally posted by HauntedMyst
Hi All,
You're in the right track with the Putnam brushes. I use Green for both sides and red/+ and green/- springs. Just make sure to polish the motors bushings and armature shafts
danjoy25 is offline
Old 08-26-2004, 12:39 AM
Thanks for all the replies!
Old 08-26-2004, 02:45 AM
S-T-R-l-K-E-R's Avatar
what ever springs you use for this make sure that the positive spring has more tension than the negative spring.
S-T-R-l-K-E-R is offline
Old 08-26-2004, 03:31 AM
lem2's Avatar
Default EPIC QUAD MAD
What's the difference of this stock motor from the MONSTER Stock?
Do we gear it the same?
thanks - lem
lem2 is offline
Old 08-26-2004, 03:49 AM
fatdoggy's Avatar
The binary 2 is very picky on gearing. I gear mine a little lower then my monsters. I run a 28mm rollout for my monster and a 26.5mm rollout for my binary 2 at my local track. It'll be different for every track though.
fatdoggy is offline
Old 08-26-2004, 06:04 AM
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
ive heard good things about the atlas brushes with the waffle on the face. does anyone know a part number? i know they have them at rainbow ten and want to try some.
dontfeelcold is offline
Old 08-27-2004, 12:49 AM
azenis's Avatar
is it ok to put a 30mm heatsink on a monstor stock? As it has the flat bits with the cooling vents on either side, is it ok if the heatsink goes over these? Will it still work?
azenis is offline
Old 08-27-2004, 12:59 AM
jiggen5354's Avatar
i find my monster stocks run cooler with out heat sinks as they block the 3 big cooling holes on the can
jiggen5354 is offline
Old 08-27-2004, 06:20 PM
azenis's Avatar
Thats what I thought...
azenis is offline
Old 08-28-2004, 11:06 PM
rinkrat99's Avatar
Hey FatDoggy
How in the world are you getting a 28mm rollout for your monster ?
I have a TC3 and in order for me to get a 26mm rollout I need a 100 spur and a 40 pinion which I do not think will even fit!
I used a 50mm tire diameter for the calculation.
rinkrat99 is offline
Old 08-28-2004, 11:07 PM
whoa, small tires dude
no even possible
try 60mm for a rubbertire
Old 08-29-2004, 12:16 AM
Brian McGreevy's Avatar
63.5 mm for rubber tires, Steve.
Brian McGreevy is offline
