Old 02-24-2011, 03:43 PM   #1
Dadic 78's Avatar
Default Explaining Slick Tire Degrees?
I'm new to on-road electric TC racing. I've just spent several hours searching out some new tires for my Cyclone TC. Looking for a rubber slick tire for carpet. I've come across many tires, and many websites, but I can't figure out what the degrees means?
For example... The same tire can come in several "degrees" variations. 24 degrees, 32 degrees, 40 degrees, etc... I assume this has something to do with the sidewall angle? I can't find an answer! Anyone know?
Dadic 78 is offline   Reply With Quote
Old 02-24-2011, 03:46 PM   #2
It's the shore rating of the tire. A lower number = softer tire.
Serzoni is offline   Reply With Quote
Old 02-24-2011, 03:51 PM   #3
Trader Rating: 24 (100%+)
You might be looking at temperature ratings. Most RUBBER touring tires have ratings based on temperature rating. It's based on a few things including tire design, the insert, and tire compound. Some manufacturers list in Celcius so be aware.
Shore ratings are primarily used when talking about foam tires.
Evoracer is offline   Reply With Quote
Old 02-24-2011, 03:56 PM   #4
Dadic 78's Avatar
So absolutely nothing to do with sidewall angle... Ah, it's good to be a noob again...
So a higher temp rating (since we're talking about rubber TC tires) would lend itself to a harder compound? Does that make sense? And thus, need to be "warmed up" to perform at it's optimal level? And offer longer life?
Old 02-24-2011, 04:01 PM   #5
I've never seen any rc tires with sidewall angle info. Hotter temp range doesn't necessarily mean "harder" compound. Simply means the tire will have it's best adhesion profile while operating within a given temp range. The insert has a bit to do with it also. And yes, some tires get better after a couple laps at speed, Long life ?? Weeeellll.....that depends ALOT on how you drive and how well setup the car is.
Old 02-24-2011, 05:19 PM   #6
Buckaroo's Avatar
click here for the thread "rubber tires for dummies", not as out of date as it seems
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
