Old 02-20-2011, 02:43 PM   #1
newera152's Avatar
Default rdx corally carpet car
hey does anyone run the RDX corally foam carpet car or can it be converted to rubber.
Custom RC Airbrushing by era1FXcustoms
Please email me at [email protected] for paint pricing, ordering and questions.
newera152 is offline   Reply With Quote
Old 02-22-2011, 06:14 AM   #2
backinblck's Avatar
It can be run as a rubber car if you change your springs and all but the chassi will work. It doen't have to torsional flex most of the newer cars have but that doesn't seem to affect anything. I ran the RDX Phi and it had the foam tire chassi in a rubber tire class and was very competative.
backinblck is offline   Reply With Quote
Old 02-22-2011, 07:11 AM   #3
newera152's Avatar
Old 02-22-2011, 08:24 AM   #4
KR145's Avatar
I've seen a few foam cars converted to rubber w/ success.
put 3 or 4 degree castor blocks on, slap on 12.5 or 14lb rear springs, and 19lb fronts and run it.
Kevin Rogers
XRAY Gtx8, Xray T4 '18
RoseCityScaleRacers
KR145 is offline   Reply With Quote
Old 02-22-2011, 11:32 AM   #5
fox88gt's Avatar
I'm pretty sure my RDX is a foam chassis, but I run it in Stock Sedan on rubber tires with very good results. I used to race it in VTA before I stepped up to the sedan class.
I'm pretty sure there are still upper decks of different thickness available if you're concerned about the chassis having too much torsional rigidity. I haven't gone that route yet, I've simply experimented with how snug or tight the upper deck screws are to the bulkheads - you can vary the amount flex depending on how tight those screws are.
Enjoy your RDX, they are on par with every hight end touring car being made to this very day.
Jeff
fox88gt is offline   Reply With Quote
Old 02-22-2011, 12:55 PM   #6
Chaz955i's Avatar
+1. We have a few people, myself included running converted foam chassis. Just need to soften the suspension up get the right caster blocks and you should have a fine car. If your car has a one way or diff up front you may want to invest in a spool or tighten the diff down. That seems to be the ticket for rubber tire on carpet these days.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Corally RDX PHI carpet spec vino1 R/C Items: For Sale/Trade 14 05-02-2008 03:40 PM
Corally Carpet Spec RDX w/hop-ups!!!! ccm399 R/C Items: For Sale/Trade 18 11-28-2005 09:31 AM
Corally RDX US carpet spec. F/S maybe F/T Eddog123 R/C Items: For Sale/Trade 26 11-22-2005 06:16 PM
Searching for a great carpet car...Pro 4, RDX, Xray05... RCknight Electric On-Road 37 04-25-2005 08:27 PM
