Old 02-18-2011, 10:32 PM   #1
Default Hobbywing 120A 1C v2.1 throttle setting problem
I just got the Hobbywing 120A 1C v2.1 , trying to set the throttle. According to the menu, hold the set button then turn it on. Wait for red light then release the set button.
I hold the set then turn it on, it has some beep beep sounds first then green light is flashing many times. It seems it is not in the throttle setting mode. What is the problem? thanks
ioxqq is offline   Reply With Quote
Old 02-18-2011, 11:19 PM   #2
fixed. there is not red light. only green in new version
Old 12-13-2013, 09:53 PM   #3
rosko's Avatar
I have this speedo and it was working fine until i used someones program box to change a few settings neutral band width and took out drag brake (17.5 blinky) and now i have steering but no throttle, blinky green light and beeping, but if i use a 2 c lipo i can set it and throttle wrks but not with 1 c battery. Need advice
rosko is offline   Reply With Quote
Old 12-13-2013, 10:08 PM   #4
Trader Rating: 27 (100%+)
You probably also turned your lipo cutoff up higher so that a 1s battery already hits lipo cutoff. Try turning that off completely.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
