Faster? Belt-Shaft >
Faster? Belt-Shaft
Faster? Belt-Shaft
Old 08-26-2004, 07:58 PM
  #61
AdrianM's Avatar
No AE drivers use the Carbon center shaft anymore. It has a resonance frequency problem at high RPM. Its most noticeable in Mod. If your car is going really fast you will hear a nasty buzzing sound come out of the car. You would swear it was about to blow apart. All the factory driver use the alloy shaft now.
This can happen to belt cars too if a long loose belt is allowed to flap out of control. It used to happen to the Tam 414, the old Xpress and the Corally C4. It doesn't happen on newer belt cars because we know how to prevent it.
AdrianM is offline
Old 08-26-2004, 08:01 PM
  #62
Is the carbon shaft still the thing to use in stock or switch over to the alloy version
mtc3od is offline
Old 08-26-2004, 08:07 PM
  #63
AdrianM's Avatar
No team drivers use the carbon shaft anymore even in stock.
AdrianM is offline
Old 08-26-2004, 08:12 PM
  #64
What is the reason? The resonating? What about the Wheel hexes. Are they using the aluminum or graphite ones?
mtc3od is offline
Old 08-26-2004, 09:24 PM
  #65
Wency_TA03R-PRO's Avatar
Exclamation
Originally posted by fatdoggy
black kat - Arms delaminate when cooked, drive shafts just break.
that explain it....
technically speaking in terms of weight between aluminum alloy and the carbon fibre shaft how big was the difference?.
Wency_TA03R-PRO is offline
Old 08-26-2004, 09:26 PM
  #66
If you have both of them you can tell by holding the end of one in one hand and one in the other hand and bounce them up and down. You will feel a huge difference. Not very scientific but works.
mtc3od is offline
Old 08-26-2004, 09:58 PM
  #67
Exclamation
ah ok.. that would be the most practical thing to verify these matter if no weighing scale available... tnx..
Old 08-30-2004, 12:54 AM
  #68
farls3589's Avatar
I finally figured it out. We can all sit hear day after day arguing about witch is better and what not but that is not goin to change anyones opinion.
losifreak I recomend you get witch ever car u like the most.
farls3589 is offline
Old 08-30-2004, 12:57 AM
  #69
GundamWZero's Avatar
Better yet get both.....and find out for yourself.
GundamWZero is offline
Old 08-30-2004, 11:06 AM
  #70
farls3589's Avatar
or you can do that.
