Old 02-17-2011, 02:38 PM   #1
Questions?? Yokomo hinge pins alternative
I'm looking for an alternative to the original steel hinge pins in my Yokomo Type C drift chassis. The steel ones are rusting so I'm looking for titanium.
The pins are 2.5mm diameter so do any other cars share this size pin that titanium hinge pins are readily available for.
The longer pins are 56.5mm long and the shorter pins are 29mm long.
Thanks.
jdm86gtz is offline   Reply With Quote
Old 02-17-2011, 04:38 PM   #2
niznai's Avatar
Not sure if that's exactly right, but you know better.
I have an SD-SSG which I suppose should have the same size hingepins. They are 3mm inboard, and 2.5mm outboard. Now that I think of it it may actually be something weird like 2.4mm outboard.
Nevermind that though.
One option readily available is to go buy a decent tool with the right size shank (pin punch for instance, but can be a screwdriver, etc.). They are not going to be titanium, but tool steel if they're a good quality, and that's as strong as it gets (albeit heavier than titanium). Cut the shank to desired length and you have your hingepins. The advantage is they are precision ground to size.
Another idea is to use drill bits. Hard to find in that length since you can only use the round part of the shank, and a compounding problem is that only part of the shank is hardened, so it will bend past that point.
Looking for titanium is a good idea, but can take a while.
I have managed to find titanium rod eventually on ebay, but even though it was advertised as 3mm diameter in fact is was 3.14 for one of them and the other was 3.12mm. That is enogh to make the suspension arm articulation stiff. I had to sand them down and it's a PITA because you have to keep it round and consistent along the length.
Even aftermarket parts made by serious companies have this problem (i.e. they're a fraction too large). I bought OEM Traxxas suspension hingepins (Titanium) with this problem, I have bought Lunsford hingepins with this problem. There is nothing else you can do about it then but sand them down with a lot of patience.
Good luck.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-17-2011, 05:18 PM   #3
The problem I had was the original pins rusted and stiffened up the suspension, I just replaced them with more steel pins but I think I'll keep looking for titanium pins.
Thanks.
Old 02-17-2011, 06:31 PM   #4
SammyZ's Avatar
Trader Rating: 138 (100%+)
nobody makes an aftermarket replacement for the yokomo hinge pins, sorry.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 02-17-2011, 06:33 PM   #5
niznai's Avatar
Thanks.
Can you polish them with some fine sandpaper? Stick'em in a drill, spin them at 3000rpm and grab with a piece of fine grit (600 or higher) wrapped around. Slide hand along as you go, so you don't thin them out unevenly. Some WD40 wouldn't hurt. They'll polish nicely.
Team Greasy Weasel
Old 02-17-2011, 08:07 PM   #6
defcone's Avatar
Trader Rating: 15 (100%+)
Roche has a titanium one for the bd5.
defcone is offline   Reply With Quote
Old 02-17-2011, 10:29 PM   #7
niznai's Avatar
Originally Posted by defcone View Post
Roche has a titanium coated one for the bd5.
fixed
Team Greasy Weasel
Old 02-18-2011, 04:28 AM   #8
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by niznai View Post
fixed
none coated....just a harden hinge pin...
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-18-2011, 05:16 AM   #9
tc3team's Avatar
Thanks.
i'm looking at this situation from a prevention rather than cure point of view.
Are you using it when its wet outside? (Hence the rusting)
Might not be the answer you are looking for though, you're not the only guy out there who likes to drift in the wet...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-18-2011, 11:17 AM   #10
New Yokomo steel pins aren't too expensive and yes I should be a little bit more careful where I use it.
So what else uses 2.5mm diameter pins
Old 02-18-2011, 12:17 PM   #11
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Doubt you'll find titanium rod in a tolerance that will be acceptable.
Check out www.mcmaster.com search for drill blanks.
Hardened steel rods you can cut to length with a high degree of accuracy on roundness and straightness.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 09:19 PM
