Old 02-20-2011, 07:26 PM   #46
Buckaroo's Avatar
Originally Posted by gonzo416 View Post
I want to buy some Savox servos but I fear the glitch problem you're talking about. I run a Tekin speedo, a Spektrum rx, LRP X-12 17.5 boosted.
You're probably fine. I'm running several Savox servos with no issues, but I always run a glitch buster cap for extra insurance with my Tekin/Spektrum combo. Been running a second gen DX3.0 with DSM1 since August 2010 indoors and out without a single problem.
The issue is with many of the newer servos drawing much more current than they ever have, thus compounding the brown out issues, and now it looks like they're drawing enough current to actually be effecting the brain in some ESCs as well. I've seen it happen, and the glitch buster always fixed it, which is why I run them even though I personally have never had an issue.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 02-20-2011, 07:35 PM   #47
gonzo416's Avatar
Trader Rating: 39 (98%+)
Where can I get them?
Do you have a link?
gonzo416 is offline   Reply With Quote
Old 02-20-2011, 07:50 PM   #48
Buckaroo's Avatar
Do you have a link?
Link to Tower Hobbies for the Novak
That's the link to the original, but it's huge and priced to match! The Spektrum one is about $6 and half the size (more cask of whiskey to the Novak keg-o-powder!!). Both work fine.
If you do a little poking around, especially on ebay, you can find them for about $5, but I'd work through my track/local hobby store (NOT Hobby Town) before paying shipping unless I was already getting something else.
List of glitch buster caps from Amain Hobbies
I run the Spektrum and a few generic ones, never had an issue with my 10th TCs.
Tom Keith
Old 02-21-2011, 01:11 AM   #49
Benzaah's Avatar
Trader Rating: 21 (96%+)
I have had good luck with INOLAB servos and they are a cheaper brand who are mainly into heli's but changing to a quality servo like the Ko servos I have had zero issues. I did start having some issues with my HW speedy and glitching issues on my then KO radio. It was suggested that i get a novak glitch buster and all my problems went away. I switched to Airtronics recently but have kept the buster in the set up as I think it makes a difference especially if you are running a personal transponder at a big event. If your handy get yourself a 10v 5600uf capacitor and solder it up with a plug and your away.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is online now   Reply With Quote
Old 02-21-2011, 01:33 AM   #50
I run a spektrum cap, but you have to be careful of the joint between the wire leads and the cap. The wires are very thin and can break. I had to re-solder one of mine, and I triple shrink wrapped it for stress relief. I think it probably broke when I zip-tied it close to the cap.
-Mike
Old 02-21-2011, 07:41 AM   #51
bigben1165's Avatar
Send a message via Yahoo to bigben1165
-Mike
what is the spektrum Cap for? glitching?
BigBen
HPI TEKNO VORZA, 2200kv, 6s maxamp, MMM, 4PKS, huge balls
bigben1165 is offline   Reply With Quote
Old 02-21-2011, 11:53 PM   #52
cheaper servos put of lot of hash & noise back into the receiver- I saw this on my oscilloscope. The cap helps filter it
Otherwise the spectrum rx will reset/restart, often (glitching)
Not needed with good servos :Futaba, KoPro etc
1101 is offline   Reply With Quote
Old 02-22-2011, 12:41 AM   #53
Yeah, basically that. When I upgraded to a used DX3R from my old 75mhz stuff, I bought it because more than a few people on the Tekin RS thread were talking about brownouts with Spektrum + Tekin causing crashes. I figured $6 and a few grams to maybe avoid that was worth it. I haven't had any issues with either a BLS551, or a Savox 1251. Just running 25.5-17.5, though. No mod, and only occasional boost.
I actually just put my extra 1251 into my 17.5 car, mostly for the hell of it. It's actually quite a bit smaller (7mm if I remember correctly) than the BLS 551 in terms of height (the dimension along the axis of the motor / output spline). Not sure if it's lighter.
It doesn't seem quite as fast, even though the spec is a bit lower. But it's still quite fast. The gears also seem less robust, judging by the amount of time I've run the futaba without stripping any gears, vs. the amount of time I ran a Savox before stripping a gear (without a servo saver in both cases). But it's hard to argue with the price and $11.50 for a gear set if you do strip it. I run servo savers in both my cars now.
-Mike
Old 02-22-2011, 07:10 AM   #54
bigben1165's Avatar
ill just get a middle of the road spektrum servo and call it good
BigBen
Old 02-22-2011, 07:19 AM   #55
Trader Rating: 24 (100%+)
Heh, Heh, You know what I'm gonna tell you !!
The servo saver comment brings up a good point. For the life of me I can't understand why anybody would try to go without one. Especially in off road use. Us touring car guys have it a bit easier but I still use one simply to balance out the load from a bump or a wreck. Some cars/trucks have a saver built in to the steering but that still translates to the servo taking a beating. Every little bit helps.
Evoracer is offline   Reply With Quote
Old 02-22-2011, 07:21 AM   #56
bigben1165's Avatar
all this servo talk is making my brain hurt i liked it better when i could buy any servo i wanted and run it without issue.
BigBen
Old 02-22-2011, 07:24 AM   #57
SteveM's Avatar
Trader Rating: 142 (100%+)
I'm using a Savox SC-1251MG Low Profile Digital "High Speed" Metal Gear Servo in my TA-05 V2, and a Savox SC-1257TG Super Speed Titanium Gear Digital Servo in my FF-03
SteveM is online now   Reply With Quote
Old 02-22-2011, 07:51 AM   #58
bigben....Now you HAVE to get a Savox. Look, even the Canadians are doing it !!!! Hi Steve !!
Welcome to forum talk Ben.....it's like information overload sometimes.
can't remember the commercial but I quote " JUST DO IT !!"
Old 02-22-2011, 08:09 AM   #59
georgec's Avatar
Savox SC-1251MG
Specifications:
Speed @ 6.0V: .09
Torque @ 6.0V: 125 oz-in / 9.0 kg-cm
Weight: 44.5g
Bearing: Dual
Type: Low Profile
Gear: Metal
Output Shaft: 25T Spline (Futaba)
Case: Aluminum Heatsink
Case Size (LxWxH): 40.8x20.2x25.4mm
Running it in a T3 17.5 sportsman class with no problems.
georgec is offline   Reply With Quote
Truggy steering servo afr0sch Electric Off-Road 29 06-02-2014 07:23 PM
Best hyper10sc steering servo Jpm1 Electric Off-Road 19 09-22-2010 08:55 PM
What Throttle SERVO Are You Running robbdny Nitro Off-Road 30 11-17-2008 11:17 PM
