Anyone ever experience arching? >
Old 08-21-2004, 08:35 PM
onebeatuptc3's Avatar
Default Anyone ever experience arching?
Today, i noticed that my wires were arching (for those of you who dont know what arching is, its when the wires cross, and can actually conduct that way, and change the flow of the electricity). I would hit the gas, and then the wires would touch and the car would stop, but then i would undo the wires and it would work, and then it would go back to arching again. Luckily i got it that the wires are away from each other now. Anyone else ever have this problem?
onebeatuptc3 is offline
Old 08-21-2004, 08:47 PM
Joel Lagace's Avatar
sounds more like a hung brush but your not giving enough info.
Do u actually see arching?
Where?
Wires twisted together should not arch.
Cheap fixes:
-clean motor inspect or replace brushes and have comm cut
-if wires are suspected (cracked or ripped insulators) replace the wires from your ESC to the motor also inspect your battery wires
Joel Lagace is offline
Old 08-21-2004, 08:54 PM
it not a hung brush because it was fixed when I seperated the wires. The wires arent cracked either, because no matter where , it still did it until the wires stoped rubbing each other.
Old 08-21-2004, 09:07 PM
Well then it can only be a cold solder joint(you have a loose wire on the esc or at the motor or a broken motor tab.
Old 08-21-2004, 09:13 PM
why do you have exposed wiring on your car?? are these battery-esc, esc-motor connections or what?
just replace any wiring on the car that isn't insulated
Rory is offline
Old 08-21-2004, 09:17 PM
all wire is unexposed, arching can happen through the rubber around the tubing (think of cars, its common with sparkplug wires) The only exposed wire on my car is on the motor tabs and thats it.
Old 08-21-2004, 09:23 PM
hmmmm, never heard of anything like that before... some people even twist motor wires around each other to reduce glitching...
maybe a faulty connection somewhere so that when the wires are touching the connection doesn't conduct, and when the wires aren't touching it does conduct? seems unlikely but i can't think of anything else it could be
Rory is offline
Old 08-21-2004, 09:24 PM
What your describing is from very high voltage situations. Thousands of volts shoot through some spark wires and worn old wires will allow grounding. I work with electronic spark ignition at work on furnaces. When wire insulators break down i can get grounding where the spark comes out he side of the wire instead of the ignitor. THE FIX? replace the wire(most never look cracked}
IF you suspect your RC car is doing the same thing as a car with poor spark plug wires then you already know what to do. REPLACE the wires from your ESC TO MOTOR TO BATTERY.
