Glitching Problems...Help Quick! >
Old 08-21-2004, 05:47 PM
  #16
most likely the arm have u checked it out yet?
Trailer of Stuf is offline
Old 08-21-2004, 05:49 PM
  #17
JDXray's Avatar
it might be the electrical board on the motor.
JDXray is offline
Old 08-21-2004, 06:07 PM
  #18
DOMOisCOOL's Avatar
Hmm, would a bad schottky cause glitching? I swapped out the old schottky with the one I always used and not THAT much glitching afterwards (with the Mako).
DOMOisCOOL is offline
Old 08-21-2004, 06:10 PM
  #19
JDXray's Avatar
maybe it was the diode. Goodluck with your car and your race.
JDXray is offline
Old 08-21-2004, 06:12 PM
  #20
Runin Ronin's Avatar
Have you checked your brushes? If they are bouncing around in there, it'll cause arcing which will make you glitch. Put on a new set, break them in and see what happens.
Runin Ronin is offline
Old 08-21-2004, 06:16 PM
  #21
Originally posted by onnetz
seems like every glitch I've ever had could be traced back to the motor.
Seems all my glitching is caused by my right or left hand.....LOL
IMPACTPLAYR is offline
  #22
DOMOisCOOL's Avatar
Thanks all for your help!
It's still glitching like before. The servo twitches, the LED on the GT7 flickers every 2 seconds and you hear a high pitched noise when it does it.
Old 08-21-2004, 06:19 PM
  #23
One other thing... When I run my car in front of my house, it also glitches like crazy.... probably the garage door openers, microwave ovens, etc around the neighborhood.
Hopefully, all your glitches are gone at the track.
Good Luck.
Old 08-21-2004, 06:22 PM
  #24
DOMOisCOOL's Avatar
Good Luck.
That might be it. It always glitches at the same part of the street. Hmm...
Thanks!
Old 08-21-2004, 06:37 PM
  #25
DOMOisCOOL's Avatar
This may be a bit off topic but my servo is making a lot of noise. At idle, it makes a lot of noise even if I take off the servo horn. Maybe one of my servo gears are stripped?
Old 08-21-2004, 06:55 PM
  #26
The glitching is a common problem with the epic style caps. Try either installing 3 more capacitors, or try soldering the loops directly to the board.
rcguy2477 is offline
Old 08-21-2004, 08:45 PM
  #27
S-T-R-l-K-E-R's Avatar
i would reprogram my esc, install 3 caps on the motor, check for frays on connctor wires from esc-rx-servo, most importantly make sure that the batts are snug tight in place - i noticed that your shaft has scratches which could mean that when you had a hard crash it loosend the batts and when it touches the shaft it shortsout and naturally glitching occurs.
another thing your power wires are touching the upper deck try running your wires over the deck C Fiber is known to cause glitching.
S-T-R-l-K-E-R is offline
Old 08-21-2004, 08:56 PM
  #28
DOMOisCOOL's Avatar
What size capacitors do I put on?
Old 08-21-2004, 08:59 PM
  #29
onnetz's Avatar
and the purpose of your post was what?
onnetz is offline
Old 08-22-2004, 01:22 AM
  #30
Tek Nickal's Avatar
0.01 uF
Tek Nickal is offline
