Thoughts about rumores of a Losi XXX-S II >
Old 08-31-2004, 09:10 PM
  #121
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Default Re: 3xs2
Originally posted by BadBoyRC
check this out xtreme mage forium
spied car new link
Did you check the dates on that forum? That's been around a while.
Jon Kerr is offline
Old 08-31-2004, 10:08 PM
  #122
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
precisely its been around a long time.
BadBoyRC is offline
Old 08-31-2004, 10:15 PM
  #123
R/C Tech Founder
That wasn't the original prototype.
futureal is offline
Old 08-31-2004, 10:20 PM
  #124
i dont think anyone denys there is a new car, the when where and what is what people dont know
Kave is offline
Old 08-31-2004, 11:43 PM
  #125
Suspended
Gabe Boudreau's Avatar
All the rumors are true...
NUFF SAID!
Gabe Boudreau is offline
Old 09-01-2004, 12:01 AM
  #126
Kenshin's Avatar
NUFF SAID!
Man, that was a shameless plug.
Kenshin is offline
Old 09-01-2004, 12:16 AM
  #127
Shop Owner
nnick's Avatar
Thank you futureal!
Nick
nnick is offline
Old 09-01-2004, 03:39 PM
  #128
imjonah's Avatar
Default Simple request
Features I would like in the new XXX-S
For starters
1. A Front bumper that protects the front suspension
2. A way to reliably set droop without taking a shock apart
3. Suspension parts which are reinforced where they are most likely to break.
4. A battery holder which works with stick packs.
5. A precise way to set gear mesh
6. pre drilled screw holes on all chassis parts
in Addition
A. I want the car to have contacts and wiring in place so I can replace the battery pack or motor without using plugs or soldering.
B. I want the electronics all to come in one unit including transponder and telemetry.
c. I want to be able to secure the body without using body clips.
d. I want calibration marks at every point where the chassis can be adjusted so I can tell the toe, camber, the droop without any tools or gauges.
e. I want the modular electronics package to record key measures like G force, wheel spin, motor temp and rpm, current going to motor.
f. I want to be able to read this data with my computer and run a program which will evaluate the data and reccomend adjustments to the car to improve it performance.
e. I want 2 channel control information I send to the car digitally encoded so multiple radios can use the same frequency.
None of the above should add significantly to the price.
imjonah is offline
Old 09-01-2004, 03:52 PM
  #129
DavidAlford's Avatar
Trader Rating: 31 (100%+)
I want a date with Danielle Fishel, can you hook that up in the kit Todd?
DavidAlford is offline
Old 09-01-2004, 05:30 PM
  #130
HarshGuy's Avatar
I'll take one with Misty Mae ...hook us up Todd!
HarshGuy is offline
Old 09-01-2004, 06:06 PM
  #131
danjoy25's Avatar
Trader Rating: 38 (100%+)
Default Re: Simple request
For starters
in Addition
The first one to come out with a car with all the above spec will the the king
I would definitely want one
danjoy25 is offline
Old 09-09-2004, 05:14 PM
  #132
Moderator
StephenSobottka's Avatar
here it is for the man who couldn't find it
StephenSobottka is offline
Old 09-10-2004, 04:28 AM
  #133
POOKYT's Avatar
Brant
POOKYT is offline
Old 09-10-2004, 04:53 AM
  #134
mcsquish's Avatar
Todge, that was a good one. If it does come with BK bones it might chew them up though. Good luck with the boxer, mine didn't slow down untill she was seven.
mcsquish is offline
Old 09-10-2004, 01:53 PM
  #135
Xtreme R/C cars ...October issue...pg. 55...there's a little paragraph talkin' bout Gil Jr. and Hodge testing a prototype.
dasupacat is offline
