Old 08-18-2004, 10:20 AM   #1
Qwiglee's Avatar
Default Four scales for checking tweak
I have seen guys using 4 small scales to setup their cars tweak. I used one last week that a guy had made himself. He had mounted all four scales on a sheet of plexiglass with adjustable legs to make sure it is level. I bought 4 small scales on Ebay but I was wondering if it is really required to have them perfectly level. I can see why it would be important for them to all be the same hieght but i was wondering if I could just set them on my pit board on my pit table and not worry about the overall level.
Anyone used these before or know the physics of the situation?
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 08-18-2004, 10:47 AM   #2
rocketron's Avatar
Trader Rating: 16 (100%+)
Default Re: Four scales for checking tweak
i've been using this method for quite awhile and would suggest that you do want them level. if they are not level you will not have the accuracy that you are trying to achieve.
rocketron is offline   Reply With Quote
Old 08-18-2004, 11:30 AM   #3
Neil Rabara's Avatar
I thought about going this route, but finding the scales was my issue. Couldn't find something that was cost effective.
Neil Rabara is offline   Reply With Quote
Old 08-18-2004, 11:32 AM   #4
Qwiglee's Avatar
I found the scales on Ebay for about $14 each. Havent received them yet so I dont know if they will work.
Brian Aldridge
Old 08-18-2004, 12:03 PM   #5
Regional Moderator
UnderDaHill's Avatar
Send a message via AIM to UnderDaHill
For touring cars the weight minimum is 1525grams so you need about 500gram capacity scales per corner.
I have 4 USX-500 scales and they work great.
PM me if you are interested in getting a set of 4. I have a contact at the USDistributor of these scales and I can order them in small quantities.
I'm pretty sure I can beat the ebay price for these scales.
UnderDaHill is offline   Reply With Quote
Old 08-18-2004, 12:05 PM   #6
rocketron's Avatar
my guess is that these are not accurate enough - based on the price you mentioned. you need gram resolution and tenths of grams best. these scales typically run from 70 and up even off ebay
Old 08-18-2004, 12:19 PM   #7
Qwiglee's Avatar
They are guaranteed accurate to within 1-2 grams. Why would I need tenths of grams?
Brian Aldridge
Old 08-18-2004, 12:42 PM   #8
ottoman's Avatar
R/C Tech Charter Subscriber
Any of these cheaper gram scales work fine. I suggest getting 4 of the same brand/style scales.
ottoman is offline   Reply With Quote
Old 08-18-2004, 03:55 PM   #9
You multiply that times four, and you get a smaller wallet size.
Old 08-18-2004, 04:25 PM   #10
Tom G's Avatar
Wouldn't the Integy scale system achieve the same effects?
I see them from the $60 [used] to $80 range [new].
Tom G is offline   Reply With Quote
Old 08-18-2004, 04:35 PM   #11
theisgroup's Avatar
you can get the irs version for less then $100 from time to time. The integy system that they sell now actually only has on digital scal that you rotate. I would think that you would have to worry about keeping the system leveled as you move the scale around. with the 4 scale system, you would have to try and get all 4 scales to calibrate. but calibration I would think are more acurate then rotating on scale to all 4 corners.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-18-2004, 04:48 PM   #12
Tom G's Avatar
I think you are correct, on both accounts. Just thought that the Integy system had more than a single scale.
Teaches me to leap beofre learning to walk, huh?
^5
Old 08-18-2004, 08:30 PM   #13
John Tag's Avatar
Trader Rating: 42 (100%+)
I bought mine at Staples 2 weeks ago and love them they were 32$ per but well worth it. with the tweak board the car was good now im able to tweak and play with front to rear % where tweak board doesnt show that I set my touring car at 12.4 ozs per wheel and love it. But thats just me everybody has there style but antway it is nice to see the actual wheel weights to see whats going on.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 08-19-2004, 08:17 AM   #14
mxs
Default scale
Can you guys give a rough idea how you proceed when setting your car up with the scale systems? Like which corner you start first, what shock do you adjust and why/
I have something like the Integy system and I am wondering whether my procedure is correct.
mxs is offline   Reply With Quote
Old 08-19-2004, 10:51 AM   #15
Regional Moderator
The scales I mentioned are VERY accurate. They measure to 1/10th of a gram.
I measure my car using all four then turned the car around 180 and measured it again and came up with the same numbers for all corners withing a couple of grams.
The integy system works ok but it doesn't take into account tires that may be slightly off. You use it with the tires removed which doesn't alway accurately reflect to the true pressure at each corner with the tires on.
I do like these scales. I got all 4 for under $70. The best I could do from an ebay seller was 85.25 after you count in their outrageous shipping costs.
Anyways... PM me if you are interested in getting four of these scales.
((Digital Scales for balancing weight and checking tweak.)) F. Mendoza R/C Items: For Sale/Trade 23 12-21-2007 03:47 AM
Pocket Scales for Tweak??? royfan33 Nitro On-Road 9 08-07-2007 05:21 PM
Tweak board with scales. EAMotorsports R/C Items: For Sale/Trade 5 12-04-2005 10:34 AM
Tweak Board with 2 mini scales smoothie R/C Items: For Sale/Trade 4 11-27-2005 07:56 PM
Is there anyone that would buy a tweak board with 4 scales for $200 usd? rcnewb2004 Electric On-Road 3 01-12-2005 10:47 PM
