Four scales for checking tweak >
Old 08-19-2004, 02:01 PM
  #16
theisgroup's Avatar
i would think another problem with the integy system is that it does not take into account the tire size. like with foams, the car will not be level when you measure. not sure if this is true, since I don't actually have the integy system
theisgroup is offline
Old 08-19-2004, 03:56 PM
  #17
Is anyone concerned with durability? When setting tweak, you want to make sure your suspension is 'activated' prior to measuring so that all shocks are at their equilibrium point. To do this, I usually push down on my car a couple times or tap it with a tool. It seems to me that small, delicate, electronic scales probably don't react well to pushing, prodding, and tapping over time. Has anyone had problems with this? Have any of you long time users checked your scales to see how well they're still calibrated?
Just a question. I've always thought the 4 scale setup was pretty trick, albeit expensive, and would be curious to hear how they perform in the long run.
Griffin is offline
Old 08-19-2004, 04:04 PM
  #18
theisgroup's Avatar
not only cool, that is how 1:1 cars are balance for the track. I believe it is called corner balancing.
