Old 02-14-2006, 12:40 PM   #256
bender's Avatar
Ran my MRT speedo for the first time last weekend
Though I only ran stock, it performed flawlessly throughout the day.
I found the turbo start feature to be very good. Whilst it didn't allow me to make up any positions at the start of the race (track has a well spaced grid), it did keep my car well clear of the guys behind me! - very handy to be able to go into the first turn without fear of being hacked
Nice size too, fitted very easy into my 415.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 02-19-2006, 03:33 PM   #257
BringItOn's Avatar
hi. i have worn thru my sckotty diode.
can you give me the specs of the sckotty diode to buy?
also in mod class. is it benificial to use drag brake?
BringItOn is offline   Reply With Quote
Old 02-19-2006, 03:42 PM   #258
heavy's Avatar
Trader Rating: 20 (100%+)
LOL That's so funny Jason. I was using my turbo start feature as well and was wondering why I wasn't catching you off the start.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 02-19-2006, 03:48 PM   #259
stuey's Avatar
you can buy diodes from most good model shops i couldn't tell you the rating with out speaking to clive or terry at mrt but i'm pretty sure it doesn't matter to much what rating they are as long as they are for model cars.
stuey is offline   Reply With Quote
Old 02-19-2006, 04:11 PM   #260
BringItOn's Avatar
yeh they are around $5 from hobby shop. but 20cents at electronics store. i need some specs so i can get them from the electronic store. i would take my old one in to compare but the markings on it have faded.
Old 02-20-2006, 02:38 AM   #261
I use 1 amp scottky diode and have found that it works pretty well. You can go to the electronic store and ask for 1 amp or 3 amp scottky diode, some people like to use up to 10 amp diodes. The only thing that matters is that it's a Scottky diode. Because Scottky diodes work much faster than normal ones.
andsetinn is offline   Reply With Quote
Old 02-20-2006, 03:45 PM   #262
V12
V12's Avatar
1 Amp isnīt enough. 3-5 Amps Schattky should be used. If you canīt get a MRT Schottky a SB540 should work also. For a hot modified 2 diodes canīt hurt.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 02-20-2006, 11:00 PM   #263
bender's Avatar
The schottky doides that come with the MRT speedies are 3.3A, 40v
Jason W
Old 02-23-2006, 11:54 AM   #264
Hi, the schottky diodes we supply are rated at between 3A and 9A. Generally the higher the spec of the diode the better. We recommend a schottky diode is used (connected across the motor terminals) to maximise efficiency and give the best performance.
Terry_S is offline   Reply With Quote
Old 02-23-2006, 03:02 PM   #265
Hi Bender, good to hear you're getting on well with your new MRT speedo.
Guys, thanks your help and advice nice to know there's support from other MRT users!
If anyone needs any info just send me a PM or an e-mail or ask here on the forum
Old 02-23-2006, 03:53 PM   #266
Burlap's Avatar
Send a message via MSN to Burlap
After hearing good reviews from F.Alonso and Bender, I'll be getting a MRT to replace my Novak GT7, which will go into another chassis.
Burlap is offline   Reply With Quote
Old 02-23-2006, 04:53 PM   #267
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
If you do a comparison chart between the two you will see that MRT one has better numbers. I'm sure you wont regret your choice
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 02-24-2006, 01:29 AM   #268
V12
V12's Avatar
Good thing is the MRT is not only very good at numbers. At the track also.
Old 03-16-2006, 09:32 AM   #269
Originally Posted by Terry_S
The MX Pro is better than the VX Pro, but then the VX Pro is still very good!! Compare the MX Pro on-resistance specs against the VX and the other manufacturers top ESC specs:
MRT MX Pro........... 0.00025 Ohms SRP Ģ99.50
MRT VX Sport......... 0.00065 Ohms SRP Ģ96.50
MRT VX Pro........... 0.000375 Ohms SRP Ģ144.50
Tekin G-10 Pro+...... 0.0004 Ohms
Tekin G-11 Pro....... 0.0003 Ohms
Novak GTX............ 0.00034 Ohms
GM SX12W............. 0.00025 Ohms
Keyence Rapida Pro... 0.00023 Ohms (better than MX Pro but Ģ189.99 in UK!)
The MRT VX/MX are 100% waterproof, apart from the GM SX12W the other ESC's are not waterproof.
So if you think the MX Pro is a very good speedo (at a very good price) how about an MX "Team" or MX "Worlds" spec? Interested in an on-resistance that's almost half of the best on-resistance specs listed above?? Think of the extra punch, acceleration and speed!!
Watch this space... the new higher spec MX competition speedos are coming...
(exact prices and specs TBA).
Old 03-16-2006, 11:59 AM   #270
I've got a MRT MX Pro.
It's very good at the track, much better then my previous speed controller.
Rob
Rob Janssen is offline   Reply With Quote
