Rotor shimming
Rotor shimming
When shimming a rotor ( 17.5 revtech ) I know it's best to get the rotor closest to the sensor without touching. When its at that point do I add shims on top to get rid of end play? Or just put the spacer and whatever it is, it is?
Not really sure but that's what a few have told me and they've been around a lot longer than me and some built their own motors from scratch
Some Racers move the rotor closer to sensor when using a high torque rotor to adjust the power band.
Higher Rpms at the cost of some torque.
Its a tuning thing...
shimming
so does end float cause variance in rpm. some motors out of the box have like .030" float. should you always shim down to say 2 thou just a little to allow for rotor to grow with heat although can should grow quicker as it is alum.
another way to put question how does sensor count, off the rotor i assume. if so the better the gap error the more even the count
i normally just buy and run em.
Here's my suggestion:
Place two .20 shims and one .10 shim on the sensor side of the rotor
Place one barrel shim on the pinion side of the rotor and assemble.
Spin the rotor and let the rotor center in the stator. Push the rotor twards the sensor. Spin the rotor again let center, then pull the rotor twards the pinion side. I usually shoot for a tiny bit of slop in both directions.
I generally believe that the motor works the best when the rotor is centered in the magnetic field.
Spin the rotor and let the rotor center in the stator. Push the rotor twards the sensor. Spin the rotor again let center then pull the rotor twards the pinion side. I usually shoot for a tiny slop in both directions.
Will see if it does anything to the performance of the motor on the weekend.
Cheers
Rob.
shimming the rotor
yep center the arm... It's how we did it back in the days of brushed motors, one of a few tricks to tunning a quicker motor...
It's just one more of the small tuning things you can do to get the most out of your motor. I have went through numerous stators and rotors trying to pair up the best float with a rotor stator combo. Things really get expensive when you are looking to pair a matched low resistance stator and a balanced specific rotor which also have a good float.
I know my fantom tuned motors usually have 2 shims which equal about 1mm on sensor board side. Any extra shims are placed on same side as barrell/pinion side of motor
If you r running a RevTech, be careful with going less than 1mm of shims on sensor board especially if u r running a 12.5HT. I fried/scrambled two sensor boards before realizing what was going on, not sure if same problem will occur with D3.5 or Killshot. Problem occurred because I was testing allot of different rotor combos in my Revtech but I would think u would still have the same issue on newer motors
idbdoug
idbdoug
The Higher the KV value the higher the RPM is what I have been seeing on a motor tester! When you adjust timing + those numbers increase. What is a good range for KV and RPM to be at to have a fast but torqy motor? How would you test for torque? Would using a High Torque rotor be the only way to increase torque? Also have been testing some rotors. Are the best rotors pretty evenly matched as far as + and - or do you want + value to be higher or lower? What are some good 12.3 rotor + and - numbers in HT, Broadband, RPM and the same question for 12.5 rotors.
