Old 02-07-2011, 03:30 PM   #1
Suspended
Default 2.4 FlySky FS-GT3B Digital 3ch TX & RX LCD Video Review
+ YouTube Video
Key Features
- Model Memory
- Servos NOR/REV
- Steering Trim
- Throttle Trim
- Dual Rate
- End Point
- ABS Settings
- EXP Settings
- Trainer Port (for VRC)
- CE & FCC certified
Specification
- Channels : 3 Channels
- Model type : car/boat
- RF range : 2.40-2.48GHz
- Bandwidth : 500Hz
- Band : 160
- RF power : less than 20DB
- 2.4G system : AFHDS
- Code type : GFSK
- Sensitivity : 1024
- Low voltage warning : yes(less than 9V)
- DSC por t: yes(3.5mmutput:PPM)
- ST range : 90
- TH range : 45(F:30;B:15)
- Charger port : yes
- Power : 12V DC(1.5AA*8)
- Weight : 328g
- ANT length : 26mm
- Size : 159 x 99 x 315mm
- Color : black
- Certificate : CE,FCC
Includes :
- 1 x 2.4Ghz transmitter
- 1 x 2.4Ghz Receiver
- 1 x Bind Plug
- 1 X Manual File in a CD
hobbypartz is offline   Reply With Quote
Old 02-07-2011, 03:39 PM   #2
Trader Rating: 48 (93%+)
i got a buddy looking to get one of these raidos.. cant beleve the 8 buck recever price...
tcb22185 is offline   Reply With Quote
Old 02-07-2011, 03:40 PM   #3
I have two of these radios, and love them. They have excellent rage (basically if you can see the car you can control it), good adjustability, and once you figure out how to use the auxiliary controls on top, the radio is very versatile.
Unfortunately the manual is very poorly written, and often completely wrong about how to do things like reverse the servo travel, etc. That can be worse than having no manual at all. It took me quite a lot of fiddling to figure out what the correct steps were.
With a decent manual, this would be an excellent radio; and at the $35 price HobbyPartz charges, it's a terrific value. But with the present manual (on the little CD that comes with it, also can be downloaded from FlySky website), it is difficult or impossible to make it work with most R/C cars.
Little-Acorn is offline   Reply With Quote
Old 02-07-2011, 06:31 PM   #4
gacjr0's Avatar
Trader Rating: 15 (100%+)
Just hope they fixed the expo problem before they sent mine.
The expo will work on one side to make the action more/less sensitive, the problem is that on the other side it does the opposite.
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 02-07-2011, 10:02 PM   #5
Trader Rating: 25 (100%+)
I was thinking of getting one of these.
ETOWN is offline   Reply With Quote
Old 02-13-2011, 08:11 AM   #6
does hobbypartz have any info on this?
do any of you guys have any more info on this problem?
urban is offline   Reply With Quote
Old 02-13-2011, 01:29 PM   #7
gacjr0's Avatar
I got mine Friday, it has the expo problem.
I did not get a cd.
I did get the USB cable!
It seems to work great otherwise.
Old 02-20-2012, 04:38 AM   #8
Hi, i really want to buy the FlySky FS-GT3B transmitter and 8 receivers, unfortunately Hobbypartz does not ship to my country (Oman),
i have a US adress which is a fright forwarder i usually use it when i shop for similar websites. sad to say i cant even use the US adress in this case because Oman is not listed in the country list in the billing adress as well.
so that mean im completely unable to purchase any products from Hobbypartz because of the shipping and billing details dont include Oman in them.
I checked with the local R/C community and they also confirmed that they are all not able to purchase anything from Hobbypartz. im hoping there is a solution to this problem
anyone please advise me on the best way to deal with this issue, your input will be greatly appreciated
Ammar
ammar577 is offline   Reply With Quote
Old 02-21-2012, 05:16 AM   #9
eddomak's Avatar
I did not get a cd.
The official thread (and help) is here. "Page 200" (with default settings) is where the summary of a lot of the thread is to be found.
The thread specifically to deal with getting custom firmware (which will fix the expo problem and do much more) is here.
Losi SCTE 1.0 - BCE Chassis, Hobbywing SCT Pro, Hobbywing XERUN 3656SD 4000KV, Hitech HS-7955TG
TLR 22T - Orion R10 Pro, Turnigy 10.5T 3250KV
Axial SCX10 Honcho | Traxxas Mini Summit VXL | Losi Micro Desert Truck | Tamiya Boomerang
Airtronics/Sanwa MT-4 | Flysky GT3B - Custom firmware
eddomak is offline   Reply With Quote
Old 02-21-2012, 05:19 AM   #10
eddomak's Avatar
Ammar
See if OverkillRC will do it for you. LosiKid (the owner) will also ship a modified version which already has the custom firmware fix on it.
Old 08-07-2016, 07:57 AM   #11
Anyone know if Hobbypartz is a US based? I was highly considering buy this Trans.
Vyevchevski is offline   Reply With Quote
