Old 02-04-2011, 06:05 PM   #1
MikeXray's Avatar
Trader Rating: 73 (100%+)
Default Why 63mm rubber tires?
How did rubber tires end up at 63mm? just for clearance on bumpy outdoor tracks? I wonder how a 57mm rim would perform, I think that indoors on high grip it would help the cars from being on the verge of flipping over. Its easy to see how little contact it takes to "peel" a car. Ideas?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-04-2011, 06:14 PM   #2
lupin_au's Avatar
Send a message via MSN to lupin_au
63 is that close to 2 1/2 inches it doesn't matter.
I'd say thats where the size comes from, the metric conversion and nothing more.
Exotek T2R | Schumacher Mission | M05 Mini | RC18R | X-Ray T2-007 EU | Tekin | Sprektrum | EDS
http://www.westcoastrccarracing.asn.au/
http://www.lupinzblog.com/
lupin_au is offline   Reply With Quote
Old 02-04-2011, 06:56 PM   #3
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 02-04-2011, 10:06 PM   #4
san.'s Avatar
Trader Rating: 60 (100%+)
The point was over looked.
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 02-05-2011, 02:21 AM   #5
I think you could be on too something, 57mm may be a bit drastic and with a modern tc we may struggle to get ride height, I'd say even going to something like a 60mm tire would massively help with traction rolling - though I think at the really big races such as the snowbirds etc there will always be an element of traction rolling!
Bony85 is offline   Reply With Quote
Old 02-05-2011, 02:21 AM   #6
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
if that were true than the tire size would be 63.5mm as that is 2.500" in when you do the math. 2.5 x 25.4= 63.5mm
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 02-05-2011, 06:05 AM   #7
MikeXray's Avatar
I picked 57 because that is what we started foams at, if memory serves me right I think we could get down to 55.5, we could always make 4mm but a foam car was a lot stiffer and rolled a lot less, that is where I think the issue may be, rolling enough to have grip and not rubbing on the track.
Old 02-05-2011, 06:17 AM   #8
miller tyme's Avatar
OR, a better option.......start running foam again
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 02-05-2011, 07:30 AM   #9
AM03GT's Avatar
well being the first TC was a Tamiya... so metric... and Tamiya is all about scale... I would think 63mm was the end result of what looked scale on a TA01...
In any case rubber tires is what it is... tune and work around the constant factor of rolling sidewalls... If we go to 57mm or smaller rubber tires it would look like we're running M-chassis wheels on a TC...
Personally I always hated that in foam tires we trued them down so much... I always started BIG at 58-59mm and drove them till they chunked bad or down to 56mm or so... The cars looked funny with a pencil line tire around the rim
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 02-05-2011, 07:34 AM   #10
alcyon's Avatar
i think it could also be due to the suspension components like hubs ,bearings, arms requiring a certain amount of space to occupy, so thats why rims cannot be made smaller than they are now, as it is i beleive rubber tyres are already at their minimum sidewall heights.
alcyon is offline   Reply With Quote
Old 02-05-2011, 08:35 AM   #11
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
In the early days a sedan racing there was some really low profile tires...I would think about 60mm or less. The problem was they never worked that well.....Just ask anyone who ever use Proline H13 tires.... Yokomo made larger rims "inch ups" that stretched the tires and made them lower profile....the problem then was wear of the tires. I think the reason the tires are as large as they are now is because this is the size that works the best. Like you said about foams 57mm....well rubber tires work best around 63mm....other sizes have been tired but this is where we are at now.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-05-2011, 10:18 AM   #12
peter_robinson's Avatar
Trader Rating: 21 (100%+)
This
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 02-05-2011, 11:32 AM   #13
MikeXray's Avatar
I'm not sure why 1/10 foam died and 1/12 didn't. I like foam, 17.5 open foam would be a fun class.
The mchassis wheels are 55mm with tire, they do look silly on a touring car.
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Generic Chit Chat with WeelNut Coxy Australian Racing 632 06-23-2004 06:33 AM
