Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 11-01-2005, 06:02 PM
  #1471
Trader Rating: 18 (100%+)
I just bought a Hara 2.1 and im woundering witch is the postive on the cap. because theres no + or - on it it just has a grey line on mone side and all black on the other so just woundering is that grey line intended for the positive? ?? Thanks in advance.
Roberto Falcon is offline
Old 11-01-2005, 06:28 PM
  #1472
kartermdb's Avatar
Trader Rating: 15 (100%+)
the line on any cap is actually the neg, happy wiring
kartermdb is offline
Old 11-02-2005, 01:20 AM
  #1473
Also the leg is shorter on the neg side.
Dan Hughes is offline
Old 11-02-2005, 01:32 AM
  #1474
The leg... is not necessarily... (at least in my experience) but the band is always negative...
rcnewb2004 is offline
Old 11-07-2005, 04:54 PM
  #1475
Default Pocket PC
Anyone using a pocket pc to store their setting for the VFS-1? I am tired of lugging a laptop to the track
Robd347 is offline
Old 11-07-2005, 05:38 PM
  #1476
Hebiki's Avatar
Trader Rating: 26 (100%+)
you can actually store profiles in your pocket pc using text files. but you wont be able to transfer it. you will still need the handheld programmer to program your VFS.
Hebiki is offline
Old 11-07-2005, 06:54 PM
  #1477
i just ordered the PC interface for my Hara Twister 2.1 to try to get a touch more punch out of the corners...i hope this helps....can anyone give me some settings they use for stock?
R/C Anonymous is offline
Old 11-07-2005, 10:57 PM
  #1478
There are some settings on the previous pages on the thread. The best way to add punch, is a combination of larger capacitor and profile adjustment. At least that did it for me.
Old 11-08-2005, 11:33 AM
  #1479
Hebiki's Avatar
tons here:
http://www.kopropo.com/vfs_help.htm
i posted within the last 6-8 pages a profile you can use for stock. check it out.
Hebiki is offline
Old 11-08-2005, 01:19 PM
  #1480
Originally Posted by Hebiki
tons here:
thank you!
Old 11-09-2005, 01:01 PM
  #1481
Default Using a 5 Cell RX Battery Pack with VFS1
Hi
I am just installing my VFS1 (J) into my 1/12th scale. I use the mini KO 302F reciever.
When I run 4 cell 19Turn, everything is powered from the main cells... however
When I run Mod I install a 5 cell pack with its own switch. I find this makes things less risky if I dump and avoids issues with Personal Transponders dropping out.
My question is about what happens to the VFS1 in the latter case. I am worried about the BEC in the speedo and my little RX batteries tring to power at the same time.
With my old Nosram Dominator Evo I did not worry about it. I turned on the RX battery switch and avoided turning in the speedo at the speedo switch when using the RX pack. I have accidentally turned both on with no ill effects but I don't want to risk that with the VFS1 unless I know it will be fine.
Please advise
Thansk and Regards
Mark
Mark Payne is offline
Old 11-09-2005, 01:07 PM
  #1482
Mark-
When using a receiver pack, you must pull the red pin in the lead going from the esc to the receiver. DO NOT CUT the wire. You will need to re-install the pin for programming the esc. I would recommend using heat-shrink or tape to make sure that the pin does not short out against anything.
You will still have to turn on boht switches. Turn on the receiver switch FIRST, then the esc.
-Robert
KO PROPO Staff is offline
Old 11-09-2005, 01:47 PM
  #1483
Thanks for getting back to me so fast Robert.
.... oh, thats a pain! I guess I am going to damage the BEC then if both end up connected?
And another question if I may.... Am I right in assuming the Battery Save voltage should be 2.3V for the 302F RX?
Am I right in thinking that if the battery voltage falls BELOW 2.3V then the speedo will take over the throttle response and overide whatever my stick is commanding in a bid to restore voltage (and keep control)?
Thanks again
Mark
Old 11-09-2005, 03:23 PM
  #1484
Mark-
You may damage something with both connected.
The battery save voltage can be set to 2.3V ONLY while using the KR-302F. When the voltage falls below the set value, you are correct.
-Robert
Old 11-09-2005, 03:29 PM
  #1485
KO=the goods
corvin12xu is offline
