Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 09-11-2005, 11:54 PM
  #1291
Trader Rating: 14 (100%+)
rcnewb2004:
Hi,
all mine were...........Gee.lets make a really cool POP noise as we go onto the straightaway.......followed by some smoke and a slight slowing of the sedan.
the only real bad one was the GT7. it did it right off the line both caps exploded.split the shrink wrap. you could see a glowing through the body, I was standing there and I just grabbed a pair of nippers and cut the - wire. no real damage just a unsoldered - lead to the caps, a cut - to bthe cells and alot of laughs at the track.
Hebiki:
Thanks for all your help!!!!!!!!!!
TimXLB is offline
Old 09-11-2005, 11:55 PM
  #1292
danjoy25's Avatar
Trader Rating: 38 (100%+)
Pop = the thing exploded with all the crap inside. Esc is working fine after but just that it was the first time I have ever seen it happen.
danjoy25 is offline
Old 09-12-2005, 12:13 AM
  #1293
hm... that sounds like a bunch of crappy caps... sorry to hear that. i haven't had a cap go off on me. (Lucky) but then again i have only had 3 speedos
If you haven't exceeded the voltage rating, i'd guess they are most likely poorly manufactured. Problems with the electrolyte inthe cap. (i could be wrong, but I can't think of anything else that causes caps to blow up)
rcnewb2004 is offline
Old 09-13-2005, 03:40 AM
  #1294
TRF 415 SA's Avatar
Default VFS1 PRO COMPETITION HELP
Hi
I have just bought a VFS1 pro competition Speedo with the handheld programmer. not good at following instructions - so i landed up not saving the original profile.
Can some help me with the original profile for the Competition model speedo
Thanks in advance
PS this is the greatest chat forum out there
TRF 415 SA is offline
Old 09-13-2005, 06:53 AM
  #1295
Iain's Avatar
TRF 415 SA,
I believe to get back to the factory settings, you just have to recalibrate the speed controller to the transmitter??
Iain
Iain is offline
Old 09-13-2005, 07:10 AM
  #1296
berger's Avatar
The default setting is 36 for each step, but i cant remember the throttle response, i would guess at it being set to 0 and the limiter at max.
berger is offline
Old 09-15-2005, 12:28 AM
  #1297
TRF 415 SA's Avatar
Berger
I was under the impression the 36 setting for the entire profile was the standard setting that appears on the handheld adaptor - seems like it is
Thats why i landed up saving another profile over the original setting
Will experiment further this weekend
Old 09-15-2005, 10:58 AM
  #1298
I will try to post the competition setting later on the KO site. It is different from the original VFS-1 Pro version. The VFS-1 Pro version has the setting set at 36 all the way across.
KO PROPO Staff is offline
Old 09-15-2005, 01:43 PM
  #1299
berger's Avatar
Oooops didnt realise the pro and the comp had different default profiles, if you could post them and i can stick the comp on my handheld to try then that would be great Robert
berger is offline
Old 09-15-2005, 03:58 PM
  #1300
Default Factory Defaults
The factory default settings are now posted for the VFS-1 Pro/J/Competition at http://www.kopropo.com/vfs_help.htm.
Old 09-15-2005, 05:30 PM
  #1301
Is the settings onthe twister 2.1 the same as those of the vfs-1pro comp?
Old 09-15-2005, 05:45 PM
  #1302
ngo8's Avatar
i have a twister 2.1 and i still have the setting adapter from the VFS-1 pro do i need a new setting card to program the twister 2.1 or i can still use the old one if i need a new setting card whats the part#?
ngo8 is offline
Old 09-15-2005, 05:58 PM
  #1303
rcnew2004- I don't beleive the setting are the same. Hara, Masami, Rayspeed and Tamiya all have different settings.
ngo8- As long as you have the VFS-1 card, it will work with all VFS-1 versions (VFS-1/Pro/J/Competition/Hara/Masami/Rayspeed/Tamiya/Corally).
Old 09-15-2005, 06:36 PM
  #1304
ngo8's Avatar
thanks ko staff
ngo8 is offline
Old 09-15-2005, 09:18 PM
  #1305
Thanks KO Staff Member.
I am curious, on other threads, i am under the impression that the upcoming g11 or the g10 pro blows the vfs-1 out of the water. How reliable are these claims?
Because I do not understand how this g11 or the g10 pro(from reading its specs) will blow everything out of the water....
Seems like just another esc... where is the "advancement" in these fields being made?
Also I am curious, why the KO never posts the internal resistance values of the ESCs like other companies?
