Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 09-01-2005, 12:42 PM
  #1261
What's the recommended gearing Hebiki?
rcnewb2004 is offline
Old 09-01-2005, 12:43 PM
  #1262
Originally Posted by KO PROPO Staff
You are probably opening the file as a text document and the numbers do not correlate to voltage settings, for example 12=120A. The numbers do not work that way. If you insist on opening it with notepad, here is the reference.
0=40A
1=60A
2=80A
3=100A
4=120A
5=140A
6=160A
7=180A
8=200A
9=220A
10=240A
11=260A
12= OFF
If you have a doubt about the setting, use the PC software to open the file. It's FREE.
chr15tophe- The numbers in the text file for brake frequency, power save, throttle response, and current limiter will appear different if you open it as a text file. Open them using the PC software.
KO PROPO Staff is offline
Old 09-01-2005, 12:47 PM
  #1263
I meant, what's the recommended gearing for that profile Alex C described? (incase there is some confusion) I have some good GP3300s that should be able to take a beating. But I am concerned about the gearing mostly.
Old 09-01-2005, 12:48 PM
  #1264
Hebiki's Avatar
Trader Rating: 26 (100%+)
i dunno? it depends on your track. at the Tamiya track, the reedy quad mags were being geared from 5.2 - 5.5 at reedy race. at socal, they're somewhere near 5.7-6.0. chameleon 2 19T are around 5.5-5.8 at my local parking lot track.
i havent raced 19T in a long long time.... robert might be able to answer that question better than me.
Hebiki is offline
Old 09-01-2005, 12:59 PM
  #1265
chr15tophe's Avatar
OK yep gotcha, but does that apply for the throttle frequencies aswell, should the throttle frequency in the text file match the graph produced in the vfs software
chr15tophe is offline
Old 09-01-2005, 01:51 PM
  #1266
JayBee's Avatar
Trader Rating: 31 (100%+)
Is this true guys that the lower the frequency the more punch you're gonna have but you have to watch the motor temps? -JB
JayBee is offline
Old 09-01-2005, 02:03 PM
  #1267
rc-zombies's Avatar
yes..lower freq. more punch..
I ran the Roar 19t setup a few weeks ago...motor had alot of rip..very hot at the finish.... next time I'll have to raise the freq. a few notches...
rc-zombies is offline
Old 09-01-2005, 02:16 PM
  #1268
JayBee's Avatar
Thanks Zombies You think I could get away with using a 19t profile for one of EA's Epic ROAR Stocks? BTW- When is that cyclone coming -JB
JayBee is offline
Old 09-01-2005, 02:17 PM
  #1269
The text file will be off by one. For example; Frequency 1 will show 0 as a text file, 2=1, and so on.
Old 09-01-2005, 02:37 PM
  #1270
Hebiki's Avatar
JB...dont you race indoors? i wouldnt worry about temps too much. if you race outdoors it'll be more of a problem. lower frequencies will require more maintenance on your motor also try putting a fan on your motor (reedy heatsink/fan combo).
Hebiki is offline
Old 09-01-2005, 02:40 PM
  #1271
rc-zombies's Avatar
I ran the profile with the Monster stock..worked pretty good....
cyclone...
Speedtech says middle of this month..
my source says end of this month...
at least it's sometime this month..we hope...
Old 09-01-2005, 02:46 PM
  #1272
JayBee's Avatar
Yeah I run indoors exclusively now. I have the heatsink/fan combo and it's working pretty good in line w/ the MMM Cooler but I'm looking to get a bit more rip outta my motors ...
JayBee is offline
Old 09-01-2005, 09:00 PM
  #1273
What's a "good" motor temp for 19T orion v2 element?
Old 09-02-2005, 11:25 AM
  #1274
J@UNE's Avatar
I'm planning to get the VSF-1. What should I buy, the pc adapter or the Multi Setting Adapter???
J@UNE is offline
Old 09-02-2005, 11:33 AM
  #1275
rc-zombies's Avatar
mine runs very hot!!
