Old 08-23-2005, 11:52 PM   #1201
Send a message via ICQ to rcnewb2004
I don't think heat would be an issue with 19T and 27T as long as your surroundings stays relatively "normal" and that you use the diode recommended by KO or its equivalent. (i think this was mentioned in the posts previous)
As for the Hara profile... I don't have my speedo yet, so i couldnt' tell ya.
Eagerly awaiting.
rcnewb2004 is offline   Reply With Quote
Old 08-24-2005, 12:17 AM   #1202
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Originally Posted by jc510
Is the stock setting for the Hara 2.1 a good start for Stock racing?
Is the Thermal issue a concern with stock motors?
I read some pages through and didn't see the info. thanks, I'm looking forward to running the ESC.
It will be very hard to thermal with using only a stock motor. Problem occurs only with low turn motors (7 turns under) Unless youve gear the motor to the moon and the track temps is hotter than norm.
Ive tried the Hara's profile and seems OK for stock.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 08-24-2005, 10:31 AM   #1203
jc510's Avatar
Talking
Thanks for the info.
jc510 is offline   Reply With Quote
Old 08-24-2005, 11:38 AM   #1204
Anyone know:
How many amps is the Ultra (single) diode rated at?
How many amps are the "normal" black silver stripe diodes rated at?
Old 08-25-2005, 05:15 AM   #1205
Default Twister 2
Hi guys i just got my Twister 2 and would like to know the following items
Is it possible to connect the Twister 2 to a Futaba HRS Receiver or do you suggest that i use a PCM one ?
For steering i will be using a digital Sanwa Servo are there any hick ups using this setup.
Also i wanted to use HRs because i can understand that with Aluminium and Carbon Fiber i will be having lots of interfereance.
Thanks for looking
speed6 is offline   Reply With Quote
Old 08-25-2005, 09:20 AM   #1206
rc-zombies's Avatar
Thanks for looking
I have no problem with mine...
and I think it will work with any system...
Old 08-25-2005, 10:29 AM   #1207
Roger's Avatar
Yo rc-zombies: Where do you race in Nor-Cal ? You got some pretty trick stuff. Maybe, we can hook up in Vallejo sometimes at Manny's track and take a few laps .
Roger
Roger is offline   Reply With Quote
Old 08-25-2005, 10:47 AM   #1208
rc-zombies's Avatar
Roger
Old 08-25-2005, 11:08 AM   #1209
rc-zombies's Avatar
Robert...
looks like the cheap laptop I just got to take to the track has max resolution of 800x600...
is there another version of the VFS-1 software that will fit a 800x600 laptop screen?...
Old 08-25-2005, 11:16 AM   #1210
Originally Posted by rc-zombies
Robert...
Nope, sorry.
KO PROPO Staff is offline   Reply With Quote
Old 08-25-2005, 11:41 AM   #1211
Originally Posted by KO PROPO Staff
You are probably opening the file as a text document and the numbers do not correlate to voltage settings, for example 12=120A. The numbers do not work that way. If you insist on opening it with notepad, here is the reference.
0=40A
1=60A
2=80A
3=100A
4=120A
5=140A
6=160A
7=180A
8=200A
9=220A
10=240A
11=260A
12= OFF
If you have a doubt about the setting, use the PC software to open the file. It's FREE.
Didn't realise you could import a file like that, tried it and explains a lot more.
Guess i should of read the text on website before jumping in the deep end
Cheers
adyb is offline   Reply With Quote
Old 08-25-2005, 05:48 PM   #1212
would it be okie if i don't install the capacitor? i'm running the hara 12x1
what would be the advantage/disadvantage?
yellow15 is offline   Reply With Quote
Old 08-25-2005, 06:15 PM   #1213
danjoy25's Avatar
advantage: your car will be 5 grams lighter & and you get to open a new esc box (I always enjoy opening new stuff)
disadvantages: Blown ESC & spend more money
Old 08-25-2005, 06:18 PM   #1214
Roger's Avatar
That explains it all. Just run the fat cap.
Old 08-25-2005, 09:07 PM   #1215
why would it blow up the ESC if i don't install the cap? i thought the cap is more like to smooth the input voltage?
KO PROPO BMC-VFS esc Molala3 Electric On-Road 0 04-23-2008 11:57 AM
KO PROPO VS-1 FS/FT Headshot R/C Items: For Sale/Trade 5 11-11-2007 06:16 PM
ko propo buffalobill989 R/C Items: Wanted to Buy 2 08-09-2006 05:08 AM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
WTB Ko Propo VFS-1 Pro Roberto Falcon R/C Items: Wanted to Buy 5 10-22-2005 11:36 AM
