Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 08-21-2005, 03:20 AM
  #1171
Originally Posted by yellow15
okie i'll try use a lower ratio and hope it'll fix the problem
but i'm just wondering how come even a 12T motor would overheat the VFS-1 ???
Well, It happens to me to have a thermal shut down even with a 23T motor because the program used was not appropriate.
Try to play with the gear ratio and the program of your speedo.
What is the program you are using ?
Ralf is offline
Old 08-21-2005, 04:47 AM
  #1172
my setting is a bit similar to the modified tech one on the ko website but it's much higher frequency (all values from mid 30- mid 40s)
one more questions..
the current limit. i notice all the settings from the ko website are set at "12" (which i assume is 120A), is it enough for all the modified motor?
yellow15 is offline
Old 08-21-2005, 11:21 PM
  #1173
anyone?
is 12 (120A i assume) enough for a 12 turn mod motors? how about a 7-8 turn?
yellow15 is offline
Old 08-21-2005, 11:32 PM
  #1174
Hebiki's Avatar
Trader Rating: 26 (100%+)
anyone?
yes. you can try higher settings. but it might just overheat the esc. hara uses it
Hebiki is offline
Old 08-22-2005, 12:02 AM
  #1175
Newb question,
The hara twister 2.1 is basically a repackaged VFS-1 ESC right?
If that's the case, do you guys think the hara program that comes with the twister 2.1 will work well with a Peak 10x1 V2 Surikarn Edition Motor?
Thanks for the replies.
rcnewb2004 is offline
Old 08-22-2005, 01:45 AM
  #1176
Hebiki's Avatar
Originally Posted by rcnewb2004
Newb question,
yes. since surikarn and hara are teammates now.
seriously.. the hara program will be good for any mod motor, the key is finding the proper gearing for your track.
Hebiki is offline
Old 08-22-2005, 10:47 AM
  #1177
hehe, that sounds cool.
So they both HPI drivers now? (sorry if i sound like a complete idiot but the name says it all).
What kind of gearing do you recommend for a shorter tighter track w/ a mod motor?
Old 08-22-2005, 11:18 AM
  #1178
rc-zombies's Avatar
Robert..
can we get a replacement Switch...
my soldering iron got a little too close over the weekend..
and also none VFS-1 related...looked throughout the KO website.
are replace servo cases available...need one for the 2364
lmk thanks
rc-zombies is offline
Old 08-22-2005, 11:32 AM
  #1179
Originally Posted by rc-zombies
Robert..
lmk thanks
A replacement switch is available $18.75 plus shipping.
A replacement case for the 236X (heatsink version servos) are available, but they are a in-house repair item only due to the difficulty in replacing the middle part of the case.
If you need just the upper case, any of the other servos (2343, 2344, 2173, 2174) will work. They are all the same, but just the servo labels are different.
-Robert
KO PROPO Staff is offline
Old 08-22-2005, 11:36 AM
  #1180
rc-zombies's Avatar
Robert..
thanks for the quick reply..
just need the upper case portion on the servo.
Old 08-23-2005, 02:24 AM
  #1181
Well, I read all frickin 40 pages of this post. (Took 3 hrs, but it was worth it) Learnt a lot. But still have some questions:
does 2x Ultimate Schotki Diode (Single) = 1x Ultimate Schotki Diode (double)?
in otherwords, when I get my hara twister 2.1, if I wanted to run a 10x1 surikarn v2 on it, I just need to buy 1x more Ultimate Schotki Diode (Single) and solder them in parallel?
Is it reasonably safe to run my motor with only 1x (single)?? (i really dun wanna spend anymore $$ on this esc... if i can get by... although i know i am getting my bang for buck)
With regards to the tempcutoff, I just want to confirm that the Hara has NO temp cutoff NOT a HIGHER temp cutoff??
And I am just curious why is having the schotki diode closer to the motor more effective than having it near the speedo end??
Lastly, does the Hara 2.1 have less FETS than the Hara 2? and I noticed there is no IR rating for the VFS ESCs, does anyone have any #s?
Old 08-23-2005, 02:58 AM
  #1182
To KO Staff:
About the VFS-1, when it is written (on the set-up) :CUR.LIM=12
It means it is 120A or the position 12 from the first one (actually NO LIMIT)
Thanks in advance
Hugo is offline
Old 08-23-2005, 06:29 AM
  #1183
EVOtech's Avatar
I'm sure KO will say different, but I would say you can run any quality Schottky diode (or two) that would be used on any other speedo. Two singles would equal one double.
I would not risk a 10T with only one diode, even if the only reason is that they say don't.
I think (only think) that the Hara 2.1 is tha same as the VFS-2, which is a cut-down VFS-1 pro. If so, it will have less FETs.
Having the diode(s) mounted on the motor provide a faster reaction to the reverse EMF they're designed to get rid of. You don't have to rely on the propogation delay and resistance of your wires to hinder it.
EVOtech is offline
Old 08-23-2005, 08:18 AM
  #1184
Along w/ the Questions in my previous postings...
I am getting all confused with all these equivalents along this thread?
KO Staff Member, you think you can once and for all just list all these equivs in one blow, to clear this issue once and for all?
Mainly I want to know:
VFS-2 = ?
VFS-1 Pro= ?
VFS-1 Pro Competion = ?
Hara Twister 2 = ?
Hara Twister 2.1 = ?
Thanks alot.
Old 08-23-2005, 08:20 AM
  #1185
rc-zombies's Avatar
I use the Novak diode.. on an 8x2 with no problems...
the Hara 2.1 is identical to the VFS-1 pro...why would Hara use a cheaper version?
