Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 08-18-2005, 11:55 PM
  #1156
Hebiki's Avatar
Trader Rating: 26 (100%+)
Robert.. sent ya a PM about your paypal addy.. also you gonna be at Tamiya on sat? let me know. thanks homie!
Hebiki is offline
Old 08-19-2005, 09:53 AM
  #1157
Lee- The terminal that is the same side as the VFS-1 lable iwith the red line (top) would be the negative terminal for the battery. The next terminal next to it would be the negative for the motor. The final one would be the battery/motor positive. I think someone posted the instruction here a while back.
centax error- Using the KR-302F, you can set the power save to any voltage setting. I would suggest using the 2.3V setting to maximize the power coming out of your batteries.
Hebiki- Info sent to you. I'll be at Tamiya tomorrow for a little while.
KO PROPO Staff is offline
Old 08-19-2005, 03:59 PM
  #1158
Hebiki's Avatar
sweet
Hebiki is offline
Old 08-19-2005, 05:03 PM
  #1159
centax error!'s Avatar
Ok. Cool!
Tnx.
CE!
centax error! is offline
Old 08-20-2005, 01:17 AM
  #1160
IN10CT's Avatar
i just got a VFS-1 MASAMI model and i want to know if the standard settings of this model could be used for a stock motor or do i have to use a mod motor?
IN10CT is offline
Old 08-20-2005, 02:04 AM
  #1161
danjoy25's Avatar
Trader Rating: 38 (100%+)
Setting is more suited for mod, I will be going to Windsor and can help to change the settings for more punch
danjoy25 is offline
Old 08-20-2005, 02:19 AM
  #1162
IN10CT's Avatar
i tried the standard settings, the thing flys. im impressed with it.
when will you be at windsor dan?
IN10CT is offline
Old 08-20-2005, 04:01 AM
  #1163
Hi there,
If it's possible to read and post the settings that would be great
I have used the stock settings from the KO website and after 4 and half mins the car slowed down, looked at the comm and it was black and had eaten up the brushes.
I know this was not a gearing problem as I've been to the track a few times and run that gearing on my other speedo(German).
What is this telling me? about the settings.
One other thing I can't get my head around ,on how some settings it goes lower as they go up in the throttle range. Would you say a '10' be slower than a '30'. Or will the top speed of both settings be the same just different how it gets to it?
Cheers
adyb is offline
Old 08-20-2005, 04:02 AM
  #1164
I'm running my pro4 with VFS-1 and a Hara V2 12x1 motor. Gear ratio is about 5.8 and after running for 3 minutes or so, the motor would suddenly stop (but can still control the steering) and after 3-5 sec then the car would go again. Seems to be thermal shut down? but i never have this problem before and today isn't hot at all (it's late winter/early spring here in New Zealand) so i wonder why is it?
i thought the VFS-1 can handle any motor so why would it have thermal shut up when running a 12 turn motor? and what can i do to fix it?
I've tried adjust my ESC settings but nothing seems to help.
I've installed the cap but i just notice today my diode disappeared (i must have lost it from a crash) would installing a diode fix this problem?
I'm running a one-way and never brakes
Anyhelp would be great!
yellow15 is offline
Old 08-20-2005, 04:15 AM
  #1165
Originally Posted by adyb
Hi there,
Cheers
Hi Adyb,
I would try increasing the whole profile of 3 steps.
Ralf is offline
Old 08-20-2005, 04:28 AM
  #1166
Yellow 15,
Yes, you experienced the thermal shut down of the VFS1.
According to me your gear ratio is too high for the V2 Hara, I would gear it around 7.5. don't forget that the Hara commutator is special compared to a regular one.
You should try the Hara program and lower everything a few stage, and yes, you should use the schottky diode, the double is better for modified racing.
Ralf is offline
Old 08-20-2005, 04:45 AM
  #1167
Originally Posted by Ralf
Yellow 15,
All the fastest guys here are using 5.5-6.0 ratio on all the different motors so if i use 7.5 there is no way i can be competitive. Is there anything else i can do?
yellow15 is offline
Old 08-20-2005, 04:55 AM
  #1168
So try a different speedo setting as advised and lower it a few stage.
Once again, I am not sure at all about your gear ratio, I own a Hara 12t and when geared at 5.5 to 6.0, the comm is burnt and the shunts of the brushes get unsoldered because of the heat.
Ralf is offline
Old 08-20-2005, 06:01 AM
  #1169
Default VSF programs!
Like adyb, If anyone wants to post your set up for either stock or mod, (im really interested in stock set us), everyonr can benifit,
C'mon guys, share the love!
Im particulaly interested in anyone who has a good set up for LARGE on rd stock!
Cheers
Simon
Bluey_74 is offline
Old 08-21-2005, 03:04 AM
  #1170
okie i'll try use a lower ratio and hope it'll fix the problem
but i'm just wondering how come even a 12T motor would overheat the VFS-1 ???
yellow15 is offline
