Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 08-17-2005, 03:23 PM
  #1141
rc-zombies's Avatar
you can always get a cheap used laptop for under $100.00 on ebay
rc-zombies is offline
Old 08-17-2005, 09:34 PM
  #1142
Can someone inform me about the BEC setting? I can change it from 2.3 to 4, but i want to know what advantages,if any, or dis-advantages there are to this?
Dhartman03 is offline
Old 08-17-2005, 09:53 PM
  #1143
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Sparx
That's what i was thinking...
Well, if i buy a VFS, i'll have a biig reason to buy a laptop
Or just get the ProComp that comes with the hand-held option -JB
JayBee is offline
Old 08-17-2005, 09:57 PM
  #1144
JayBee's Avatar
KO PROPO Staff-
Did you get that paypal? -JB
JayBee is offline
Old 08-17-2005, 10:05 PM
  #1145
danjoy25's Avatar
Trader Rating: 38 (100%+)
If I want to have a similar reactive frequency setting as an LRP Ouantum 2, would the frequency setting be just 1-64.
danjoy25 is offline
Old 08-17-2005, 10:31 PM
  #1146
well, that would be a basic setting, but you can mess around with different frequencies. I tried that setting and its really effcient since your at 3/4 to full trigger all the time, but if you want alot of punch out of corners try the opposite, 64-1. When you go to rip on it out of corners, its getting punchier, but not as effcient, so its all about your driving style and how efficient you want to be.
Old 08-18-2005, 03:53 AM
  #1147
V12
V12's Avatar
Emm, i'm thinking of buying a VFS1 Comp and to make my question short. Can i use the VFS 1 "Programming program" on a Macintosh Powerbook B3? Cuz that's the only "computer" i can take to the track..
*edit* After closer inspection of the Mac, it doesn't even have a COM-port. Crappy POS
There are some Com/USB converters so this maybe isn´t a problem but according to the KO website Windows is required.
V12 is offline
Old 08-18-2005, 11:10 AM
  #1148
The 2.3V setting should only be used with the KR-302F receiver. Most other receivers should be able to handle 2.5V setting. Spektrum should be set no lower then 3.5V.
This setting is the lowest possilbe incoming voltage of the battery before the BEC is activated. This allows you to get the most out of your battery pack.
KO PROPO Staff is offline
Old 08-18-2005, 11:19 AM
  #1149
rc-zombies's Avatar
KO/Robert
I thinking of getting a cheap mini laptop to take to the track that has com port.
will the VFS-1 software work on Windows CE (pocket pc) OS?
lmk thanks...
Old 08-18-2005, 11:29 AM
  #1150
Originally Posted by rc-zombies
KO/Robert
lmk thanks...
I've never tried it so I wouldn't know. Sorry.
Old 08-18-2005, 11:56 AM
  #1151
rc-zombies's Avatar
after some searching the answer is no..
this is what I came up with...
Q: Does Windows CE support DOS or Windows applications?
A: No, Windows CE is a new operating system. The programs for Windows CE are completely different than DOS or Windows applications. Windows CE is a true multitasking and multithreaded operating system, you can even run 2 or more applications at the same time. It is Win32 API compatible except it does not have all the extensions available such as MAPI, OLE, DDE, etc
Old 08-18-2005, 03:22 PM
  #1152
JayBee's Avatar
Got the package back Robert, THANX -JB
JayBee is offline
Old 08-18-2005, 08:47 PM
  #1153
KO PROPO STAFF,
I just got a used VFS-1. Only thing is I need to know which terminals are which. Also would like a .pdf of the setup amd manual sheet.
If I like this thing I'll definitly buy a couple of new ones!
Lee H is offline
Old 08-18-2005, 08:52 PM
  #1154
Roger's Avatar
Lee: You'l like it alot . If you need help, I can help you since your local for me.
Roger is offline
Old 08-19-2005, 12:47 AM
  #1155
centax error!'s Avatar
Robert, What will happen if I set more tha 2.3V on my 302f receiver? I am not paying attention on this part when I change the profile
CE!
centax error! is offline
