Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 08-15-2005, 03:12 PM
  #1126
JayBee's Avatar
Trader Rating: 31 (100%+)
Robert-
Did you get the package? -JB
JayBee is offline
Old 08-15-2005, 03:25 PM
  #1127
Originally Posted by HarshGuy
What is the current limiter setting for? ...the "label" seems to imply that the esc would not deliver more than the current indicated in the drop down ...if that is the case, why qould you want that ..seems like you'd want "all the jiuce possible" to get to the motor?
The current limiter is so that you do not "waste" power. As an example: in a 60 foot straight you car can pull all the way down the straight with the current limiter set to 180A. You change the current limiter to 120A and can pull the same speed and lap times. You have now just did a little battery management and your runtime should increase due to not "wasting" an extra 60A that the motor could draw. You can however set this too low and see that the car will no longer will pull the straight and may become less aggressive.
Mainly if you are having runtime issues, this is an option to get a little more runtime.
KO PROPO Staff is offline
Old 08-15-2005, 03:33 PM
  #1128
Trader Rating: 19 (100%+)
...maybe everyone else has just bought more motor since you raced last
...its not his motor Harsh. I personally guarantee it!
Advil is offline
Old 08-15-2005, 04:15 PM
  #1129
Roger's Avatar
Yeah, Advil is my motorman and his motor are ballistically fast when my esc is properly calibrated with my M11.
Anyways, this is what happened. I wasn't getting full throttle from my radio. It just so happened that I just got a new M11 radio and I calibrated that with my spektrum perfectly. But, ( stupid me ) I forgot to calibrate my radio to my esc. I was only getting 3/4 throttle during the whole day, but still managed to qualify 6th and finish in 6th in the A. I noticed it when I was playing with the throttle trim on my car. When I cranked it up, the car wouldn't move as much. But, when I resetted the tx to the esc, the esc was working like a champ.
Roger is offline
Old 08-15-2005, 05:20 PM
  #1130
berger's Avatar
Managed to test my speedo tonight with everything on my bench and it works still... Guessing the thermal cutoff just kicked in and the slight smoke someone saw was traction compound or something evaporating if it had been spilt near the speedo/motor.
Dont want to repeat going from full chat with a 7 single to stopped dead on the back straight though!
Ill try and test it out in stock and make sure its working ok again before i do some more modified.
berger is offline
Old 08-15-2005, 08:44 PM
  #1131
Default Hella Fast Car!!!
Roger,
Will you be looking for "victims" on Saturday or Sunday this weekend?
Advil is offline
Old 08-15-2005, 09:25 PM
  #1132
centax error!'s Avatar
Default profile for twister 2.1
anyone has a profile for hara's twister 2.1? please share.
thnx.
CE!
centax error! is offline
Old 08-15-2005, 10:37 PM
  #1133
Roger's Avatar
Roger,
Oh yeah, there's gonna be some victims saturday at Ripon !!!
Roger is offline
Old 08-16-2005, 02:17 AM
  #1134
i know there are setups for 27T motors out there but does anyone have any suggestion for a rs540 motor to get the best out of it any help would be great
cheers
judge10tpt is offline
Old 08-16-2005, 07:03 AM
  #1135
HarshGuy's Avatar
ahhh ...yepo that would do it ...so do you have the pc software for it? ...you can dial in that speedo to your hearts content I love this speedo, I actually own 4 of them, one in each car, a backup one, and one I picked up on ebay (I guess a "backup to the backup" )
HarshGuy is offline
  #1136
HarshGuy's Avatar
ah ...sounds like end user error then
HarshGuy is offline
Old 08-16-2005, 10:19 AM
  #1137
Roger's Avatar
Javs: Yeah, I have the handheld programmer for my esc. I need to buy another VFS-1 for back-up.
Roger is offline
Old 08-17-2005, 01:30 PM
  #1138
Tommy Bergfeldt's Avatar
Emm, i'm thinking of buying a VFS1 Comp and to make my question short. Can i use the VFS 1 "Programming program" on a Macintosh Powerbook B3? Cuz that's the only "computer" i can take to the track..
*edit* After closer inspection of the Mac, it doesn't even have a COM-port. Crappy POS
Tommy Bergfeldt is offline
Old 08-17-2005, 01:43 PM
  #1139
Hebiki's Avatar
Trader Rating: 26 (100%+)
unless you have a program that can emulate a windows environment (like soft windows). i dont think it'll work. the VFS program is a .exe
Hebiki is offline
Old 08-17-2005, 02:21 PM
  #1140
That's what i was thinking...
Well, if i buy a VFS, i'll have a biig reason to buy a laptop
