Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 07-29-2005, 12:53 PM
  #1066
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Alex C
Chris,
If it was not for you, I would not have had any real starting point.
Thanks Again Chris for the vote of confidence.
Best Regards
Alex
got an even better one.. let me know if you want it ill PM ya
good luck at the Sizzler Race! bring it home for Ko Propo
Hebiki is offline
Old 07-29-2005, 04:30 PM
  #1067
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Hebiki, PM me with that new profile. I want to try it this weekend against one other profile you gave me -JB
JayBee is offline
Old 07-29-2005, 05:07 PM
  #1068
Hebiki's Avatar
i havent received your paypal bribe yet. alex C. sent his over already! JK!
you should see it in a few mins. ill send it right over
Hebiki is offline
Old 07-29-2005, 07:34 PM
  #1069
JayBee's Avatar
You should see your paypal bribe in a few minutes... -JB
JayBee is offline
Old 07-31-2005, 05:51 PM
  #1070
dawgmeat's Avatar
Default Dawg
whatis the recomended powersave voltage using a spektrum and 2 motor fans?
dawgmeat is offline
Old 07-31-2005, 06:09 PM
  #1071
dawgmeat's Avatar
1 more thing , I tried to download the profiles from KO website,but when I'm done downing and try to open it, it says that I don't have right software to open it?
dawgmeat is offline
Old 07-31-2005, 06:59 PM
  #1072
berger's Avatar
If you dont have the software to transfer from a pc to the vfs-1 then use notepad, it should show you the values that everything is set to and then you can use the handheld controller to input them manually.
berger is offline
Old 07-31-2005, 10:22 PM
  #1073
JayBee's Avatar
Am I correct in thinking that I can use use 4 AA in a battery box as a power supply that's insisted on in the manual when you're using the PC adapter to adjust profiles on a laptop? -JB
JayBee is offline
Old 08-01-2005, 10:24 AM
  #1074
Dawgmeat-
You can download the software for free from the KO website and use that to open the files.
When using spektrum you should set the power save to a minimum of 3.5V, otherwise you will run into the problem of the receiver re-booting.
-Robert
KO PROPO Staff is offline
Old 08-01-2005, 10:28 AM
  #1075
rayhuang's Avatar
Thanks Alex C-good to meet you this weekend. I am sorry I did not see this till today. But I will print this and keep it.
Ray
rayhuang is offline
Old 08-01-2005, 10:34 AM
  #1076
JayBee's Avatar
KO PROPO Staff,
I repeat - Am I correct in thinking that I can use use 4 AA in a battery box as a power supply that's insisted on in the manual when you're using the PC adapter to adjust profiles on a laptop? -JB
JayBee is offline
Old 08-01-2005, 12:11 PM
  #1077
KO PROPO Staff,
Jaybee- I don't think that I understand you question. Did you want to connect the PC interface to the hand held programmer? If so, it doesn't work.
Old 08-01-2005, 12:26 PM
  #1078
dawgmeat's Avatar
Originally Posted by KO PROPO Staff
Dawgmeat-
-Robert
Thanks Homie
dawgmeat is offline
Old 08-01-2005, 12:54 PM
  #1079
JayBee's Avatar
I know I can't connect the PC adapter to the hand held programmer. I didn't mention anything about that in my question. In the PC adapter instructions it shows a picture of the adapter w/ a y-harness. One connects to the servo and the other to a Power Supply of (DC 4.5V-6.5V). Does that help to answer my question? -JB
JayBee is offline
Old 08-01-2005, 01:19 PM
  #1080
Alex C's Avatar
Trader Rating: 50 (100%+)
Ray
Any time Ray,
It was great to meet you, I am just glad you did not have a problem, like Rob K.
If you have any questions feel free to pm me.
Best Regards
Alex
Alex C is offline
