Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 07-26-2005, 02:56 PM
  #1051
thanks Hebiki
erock1331 is offline
Old 07-27-2005, 06:33 PM
  #1052
rayhuang's Avatar
Default 3-questions!!
Thanks in advance for help:
1. Help-where do I find a reference guide for what the steps are and what frequency they refer to. i.e 1=920hz, 2=....
2. Also-can someone please advise me on a good 19t set-up for a carpet/foam 95x50 ft track?
3. And last-what value for throttle response are you guys using for low turn (7x1 and 8x1) mod/carpet/foam?
THanks again,
Ray
rayhuang is offline
Old 07-27-2005, 09:07 PM
  #1053
hey ray are you going to be at the sizzler this weekend if so i can hook you up brother ive got a killer stock and 19t profile and a very good mod one too.
goop is offline
Old 07-27-2005, 09:28 PM
  #1054
rayhuang's Avatar
Thanks -I'll be there. I plugged in the kopropo generic high speed mod set-up to start.
Thanks,
Ray
rayhuang is offline
Old 07-28-2005, 05:24 AM
  #1055
utieh's Avatar
I don't know if this question had been asked before, what's the difference between the VFS1 and VFS2??? I've been told that the VFS2 can also stand mod motors.
Thanks.
Gilles
utieh is offline
Old 07-28-2005, 10:45 AM
  #1056
V12
V12's Avatar
Hmm Im not sure if the VFS-2 should be used with hot motors. Its just a budget version of the VFS-1 with less FETs.
V12 is offline
Old 07-28-2005, 09:20 PM
  #1057
Alex C's Avatar
Trader Rating: 50 (100%+)
[rayhuang]Thanks in advance for help:
Attached below is a pdf attachment which shows you each frequency step.
I currently run the setup below which I helped Goop with.
I would Recommend running this profile only if you have some good Gp3300 Packs with some runtime say 420. You can also adjust the Current limiter value which will give you more rip out of your motor(the higher the value the more current which is applied to the motor), the key thing to look at is the temp of the motor in addition to the brush life.
Current limiter: 160
Neutral brake: OFF
Throttle response: OFF
Power save voltage: 2.5 BEC
Frequency of brake: 32
5 <--- starting point for throttle curve
5
4
4
4
4
4
4
3
3
3
3
3
3
2
1 <--- throttle half way pressed (stage #16)
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17 <--- throttle fully pressed
There is Nine stages (off and 1-9) that can be set, One becoming the most Aggressive, and 9 becoming the mildest. Please test and look at the conditions of the track because the effect will differ. This may also be effective when combined with the throttle punch funtion of the transmitter when the track conditions are slippery and the motor is too aggressive.
As to what profile to run, I would Recommend running the Hara Worlds Profile for Touring car which can be found under the US Ko Propo Web Site http://www.kopropo.com/vfs_help.htm. Also I would recommend running the Ko Propo VFS-1 Pro Double Shotki Diode Part#KO45516 if you plan on running MOD.
I will also be attending the Sizzzzlllaaaaa, so If you still have questions or any concerns please dont hesitateto ask.
Best Regards
Alex C
File Type: pdf
Alex C is offline
Old 07-28-2005, 10:12 PM
  #1058
JayBee's Avatar
Trader Rating: 31 (100%+)
That diode pictured is not the double, that's the single. The double's thickness is a tad more than twice of the one pictured. Just to help out if someone had a question of the two ... -JB
JayBee is offline
Old 07-29-2005, 12:28 AM
  #1059
Hebiki's Avatar
Trader Rating: 26 (100%+)
Neutral brake: OFF
5
4
4
4
4
4
4
3
3
3
3
3
3
2
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
As to what profile to run, I would Recommend running the Hara Worlds Profile for Touring car which can be found under the US Ko Propo Web Site. Also I would recommend running the Ko Propo VFS-1 Pro Double Shotki Diode Part#KO45516 if you plan on running MOD.
Best Regards
Alex C
alex... nice profile. i didnt know someone actually read that PDF i made!
- chris
Hebiki is offline
Old 07-29-2005, 10:08 AM
  #1060
Alex C's Avatar
- chris
Chris,
If it was not for you, I would not have had any real starting point.
Thanks Again Chris for the vote of confidence.
Best Regards
Alex
Alex C is offline
Old 07-29-2005, 12:16 PM
  #1061
BritRacer's Avatar
Is the cable for connection to PC a standard serial cable?
BritRacer is offline
Old 07-29-2005, 12:32 PM
  #1062
rc-zombies's Avatar
no it is not...there is a circuit board inside the cable case.
rc-zombies is offline
Old 07-29-2005, 12:39 PM
  #1063
BritRacer's Avatar
bollox.
So where is the best <cheapest> place to get one? KO Shopatron?
Old 07-29-2005, 12:43 PM
  #1064
rc-zombies's Avatar
bollox.
or have your LHS order one...
Old 07-29-2005, 12:50 PM
  #1065
Mr. Shookie's Avatar
http://www.speedtechrc.com/store/ebp...nid=57&id=4566
Out of stock right now but give him a couple days...LOL
-Shookie <><
bollox.
Mr. Shookie is offline
