Old 07-11-2005, 03:25 AM   #991
Yesterday, we had a speed record day on a oval course, I drove a corally RDX with the new MMS3 speedo on 6 cells (same as KoPropo ) and a black series 7 turn. The car went 115 KMH about 71mph.. I had no problems with te speedo..
You can remove the terminal overload protection on jour vfs-1, it's verry simple and prevents the speedo to go in a overload protection to early. I didn't do it because I have no problems with it.. I wil see If I can post a sheme of the vfs-1 that i got from KoPropo
Bart
Bartwubben is offline   Reply With Quote
Old 07-11-2005, 05:50 AM   #992
berger's Avatar
R/C Tech Charter Subscriber
Originally Posted by danjoy25
I seen it happen with someone running a 6turn. Only made the 2 minutes mark
What profile were they running, a massive amount of other factors have to be included before you can blame the speedo.
berger is offline   Reply With Quote
Old 07-11-2005, 12:47 PM   #993
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by alan1467
Anyone had their VFS-1 shut down running a low turn mod on a very hot day?
I think the speedo is getting to hot but not sure?
guys if you are running the older VFS-1. if you have not modified it (im sure if you modify it personally, all warranties will be void) it will shut down if the following things are done incorrectly:
1. too aggressive of a set up. the stock set up is set at 36 across. going too far below this (say 17 or 18) will definitely heat up the ESC faster.
2. incorrect gearing on the motor... this will definitely overheat the ESC and shut it down faster.
3. driving style... a driver who drives more "punched" than someone who is smoother will definitely overheat it faster.
4. if the track temp is super hot (i raced yesterday, our track temp got up to 140 deg. F.) that heat is just coming off the asphalt and into the car. this will also contribute to the esc overheating.
Here are some solutions i suggest that can help cool the esc down:
1. put a heatsink on it. steve at speedtech has one. here's the link:
http://www.speedtechrc.com/store/ebp...nid=57&id=5243
2. put a fan ON TOP of the esc. the small fans work great. here's a link:
25mmx25mm: http://www.speedtechrc.com/store/ebp...id=395&id=5219
30mmx30mm
http://www.speedtechrc.com/store/ebp...id=395&id=5218
3. although the best solution would be to purchase the VFS-1 Competition. a more affordable solution would be to remove the cutoff as someone stated above. send it to Ko Propo so they can do it professionally.
4. run a more conservative drive profile
5. run a more conservative gearing
6. drive smoother
hope that helps guys.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-12-2005, 03:04 PM   #994
Matt Howard's Avatar
So there is a way to bypass the thermal shutdown, or at least raise it, on the regular VSF-1? Can someone post how to do it? I know it will void the warranty but would like to do it anyway.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-12-2005, 03:15 PM   #995
HarshGuy's Avatar
Run stock.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 07-12-2005, 03:15 PM   #996
rc-zombies's Avatar
Steve should be able to get the Alex Racing KO heatsinks...
available in a variety of colors to match any car.
http://www.alex.ne.jp/rc/newproducts/0504.html
Robert...
is is possible to buy the new CF print case?
Old 07-12-2005, 03:27 PM   #997
Originally Posted by HarshGuy
Run stock.
I probably will occasionally since it's the biggest TC class in Omaha. I'll still run mod whenever I get the chance to though.
RCTech #361
Old 07-12-2005, 03:46 PM   #998
Here is a sheme of the koPropo vfs-1.. there are 2 ways to by-pass the terminal overload protection.. One is verry simple, you just cut the little wire in the 2 boards. the other is more difficult.. you have to remove the little ciruit chip en then fill it with solder thin..
Good Luck,
Bart
Old 07-12-2005, 03:46 PM   #999
Matt- You should probably send it in for service to do it. If you try it (cut the thremo) yourself, you'll probably damage the PC board. Temp restistor for higher cut-off can be changed out, but will definitely require service.
zombies- The case will not be available. I've already tried to get some.
When using the KSC heatsink on the VFS-1, you will need to use 3 strip of heat transfer tape on the side where the VFS-1 logo is. The reason is because the heatsink will not sit flush with out it. The other option is the grind down the opposite side of the heatsink to fit properly. In testing, I have found that there is a 6% decrease in ESC temp with this heatsink. I have tested with another heatsink that was smaller and there was only a 2% decrease in temp. This was probably due to less mass in the heatsink and less SA. I can't really recommed it, but the facts I beleive speak for themsleves.
KO PROPO Staff is offline   Reply With Quote
Old 07-12-2005, 05:52 PM   #1000
danjoy25's Avatar
Trader Rating: 37 (100%+)
Good Luck,
Bart
Can someone confirm if cutting the connection will work as it seem very easy. What is then the downside of not having the terminal overload protection? Would the chance to smoking the esc increase when running hotter motors like 7-8 turns?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-12-2005, 07:40 PM   #1001
Regional Moderator
daniz24's Avatar
Hara said that all of his Speedos has no thermal cutoff, and they're are not easily broken. I think the thermal cutoff is just being too safe.
daniz24 is offline   Reply With Quote
Old 07-12-2005, 07:49 PM   #1002
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
So a heatsink is not needed than? I'll just buy a fan for it ^_^ So the VFS-1 Pro Comp comes with the big diode not the double shotki diode? And you only need the double shotki diode for modified racing 10t under right?
vi3tishduy is offline   Reply With Quote
Old 07-13-2005, 03:51 AM   #1003
Hi,
When you remove the little connection you wil not have a terminal overload protection any more!! I heard most of the team drivers do this mod..We received this info from KoPropo so it must be good..
Bart
Old 07-13-2005, 08:07 PM   #1004
HarshGuy's Avatar
Just wanted to give props to KO for awesome service!! I sent my speedo which I messed up by leaving on for 2 days ...last Thursday 07/06 ...I got a call today from KO saying it was fixed and charge only $22.00 AWESOME SERVICE!!!
Old 07-15-2005, 09:59 PM   #1005
Mr. Postman's Avatar
Send a message via AIM to Mr. Postman
Attention KO Propo Staff.
YGPM
TC
CoBroRa/TaoB
Mr. Postman is offline   Reply With Quote
KO PROPO BMC-VFS esc Molala3 Electric On-Road 0 04-23-2008 11:57 AM
KO PROPO VS-1 FS/FT Headshot R/C Items: For Sale/Trade 5 11-11-2007 06:16 PM
ko propo buffalobill989 R/C Items: Wanted to Buy 2 08-09-2006 05:08 AM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
WTB Ko Propo VFS-1 Pro Roberto Falcon R/C Items: Wanted to Buy 5 10-22-2005 11:36 AM
