Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 07-05-2005, 10:58 AM
  #976
Originally Posted by kennykay
Hi Robert,
Can you teach me how can I connect my electronics together for my Asso 12L4? I have a KO VFS1, KO 302F, a KO 949ICS and I am planning to use receiver pack.
Do I need to avoid connecting the red wire of the VFS1 to the receiver?
Help me please.
Regards,
Kenny
Kenny-
Remove the red wire from the wiring harness going to the receiver. DO NOT CUT the red wire, just remove it from the plug by pushing in the pin that retains the plug into the harness. Now your VFS will only power the motor. You will need to re-insert the red wire to the harness program the VFS.
Plug your receiver pack into the receiver directly. You will still need to turn on the receiver pack (if you have a switch) and turn on the VFS.
-Robert
KO PROPO Staff is offline
Old 07-05-2005, 07:35 PM
  #977
Originally Posted by KO PROPO Staff
Kenny-
-Robert
Robert, Thank you!
Regards,
Kenny
kennykay is offline
Old 07-06-2005, 10:11 AM
  #978
HarshGuy's Avatar
With the spektrum receivers, the power save must be set at 3.5V in the VFS. If not, the receiver will go into a reboot and must be binded again to the module.
You can send it directly to KO PROPO USA. Labor is a flat $11.00 plus parts and shipping.
OK I'm sending the unit in, about how long to get it back? I picke up another one and it works perfectly so definetely I somehow fried the unit by leaving it on for 3 days
HarshGuy is offline
Old 07-09-2005, 02:00 AM
  #979
danjoy25's Avatar
Trader Rating: 38 (100%+)
Got a 2nd hand VFS-1 and need to find out how to set it up as did not get any english manual or if there's a link for me to download it.
Do I also need to run the KO diode? I run 7-9 turn motors but only use brakes during lining the starting grid , stopping when race is finish or trying to avoid an accident but never during racing.
danjoy25 is offline
Old 07-09-2005, 04:19 AM
  #980
Hebiki's Avatar
Trader Rating: 26 (100%+)
danjoy! please please please use a double diode from Ko. trust me.. i toasted an esc because i forgot to attach one. you dont want that.
if you got spare time.. go back about 7-8 pages. i wrote step by step instructions on how to get the VFS set up. of course you'll need either the software (on a laptop with the proper connectors) or the handheld programmer.
let us know if you need any help
Hebiki is offline
Old 07-09-2005, 04:30 AM
  #981
danjoy25's Avatar
Found the manual and got it working, initial setup that is. Not really fuss about adjusting the parameters for now. Default setting for now will be fine.
About the diode, can I just use to normal diode as I can't access a KO one tomorrow. do I need to use more than one and how do I go about it?
danjoy25 is offline
Old 07-09-2005, 10:09 AM
  #982
vi3tishduy's Avatar
Hebiki what esc is that?
vi3tishduy is offline
Old 07-09-2005, 10:14 AM
  #983
vi3tishduy's Avatar
Another question, does the VFS-1 Pro Comp come with wires to solder? And do I have to purchase the Shotki Diode separately?
Old 07-09-2005, 10:18 AM
  #984
The VFS-1 Pro Comp. comes with wires and Shotky Diode .
darulor is offline
Old 07-09-2005, 10:33 AM
  #985
vi3tishduy's Avatar
Hmm... So whats up with people soldering the KO diode and that big round object? Which one does it come with? And whats the part number for the big round diode?
Old 07-09-2005, 02:45 PM
  #986
something is missing ...........
and need to buy the double Shotky Diode (options items ) to soldered near by the motor. The double Shotky Diode is protect the ESC , when u use 10t motor or under (like 9t, 8t, ......etc)
rayspeed-SD is offline
Old 07-09-2005, 06:15 PM
  #987
Myker*'s Avatar
tamiya volac ms, same as the VFS-1.
Myker* is offline
Old 07-10-2005, 08:40 AM
  #988
Hi guys, could you tell me if the new updated fets are actually different or is it just the temp cut off thats changed?
Basically, what I want to know is if the internal resistance has dropped a little with these 'new' Fets..?
Thanks in advance!
Tbevofreak is offline
Old 07-11-2005, 03:04 AM
  #989
alan1467's Avatar
Anyone had their VFS-1 shut down running a low turn mod on a very hot day?
I think the speedo is getting to hot but not sure?
alan1467 is offline
Old 07-11-2005, 03:07 AM
  #990
danjoy25's Avatar
I seen it happen with someone running a 6turn. Only made the 2 minutes mark
danjoy25 is offline
