Ko Propo VFS-1 ESC
#916
Originally Posted by NorCal_Big_L
I figured out my problem, I was missing the USB Controller driver. But now it's all good, I am upm and running on the laptop! Here's the pic of my FK05 with the VFS-1 i it. Thanks Hebiki for sharing set ups and everyone who replied on my problem.
#918
Originally Posted by Hebiki
sweet. let us know how your racing goes!
#919
Originally Posted by RC12L3a
dear ko staff:
The folowings are the components for my 8T 1/12:
1. KR-297FZ 40 FM KO Receiver
2. VFS-1 Pro, default setting
3. KO PDS-949ICS servo
4. KO ex11 presto
and below are my questions:
1. There are some beeping sounds from my servo since the frist time i tried it on pit table ....why??is it normal or what?
2. what i need to take advantage of the "digital" character of my servo?
3. can i add a receiver cap? (when i do not use a receiver pack...of coz)
4. if i am minded to avoid glitching/jamming due to over motor amp draw...should i tune UP the BEC in my VFS1 (4V), or tune it down?
thanks a lot.
4. KO ex11 presto
thanks a lot.
1. I have never heard a beeping sound coming from the servo. Is it a buzzing sound? Digital servos will always buzz because they are trying to stay at center. If it is constantly buzzing, you may want to check your linkage or your servo saver. It should stop now and then.
2. The stock setting is fine in the servo. Digital just means that it is more precise and has more holding power compared to an analog servo. Download the servo program to see what you can adjust. Some people like to play with the settings.
3. You can use a receiver cap, it won't hurt. But when using a receiver pack to power the servo and receiver, you MUST remove the red wire in the wiring harness from the speed controller to the receiver. DO NOT CUT the wire, just remove it from the harness. You will need to re-install the wire for programming.
4. With the KR-297FZ receiver, you will need to have the power save set no lower then 2.5V. You will run into problems if you do not remove the wire as mentioned in #3 when using a receiver pack. You can set the BEC voltage higher if you are having problems with runtime and power.
#920
Have KO just released a new speedo?
I.E. the same as the hara twister 2.1?
#921
hey guys i just got a hara twister2 and it seems really slow in 27t and 19t, i put my gtx in and the car had alot more punch and topend. Do you know if it is just the stock setup of the speed control or if you think there is a default in the controller thanks
#922
Originally Posted by daniz24
Masami VFS Profile
Surly we can get one of these capacitors from our local electronics component store?
#923
#924
SO try this and have fun.
#925
#927
is it out yet?
#928
Originally Posted by KO PROPO Staff
Maybe
They just came in today.
