Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 06-09-2005, 12:29 PM
  #901
Originally Posted by NorCal_Big_L
I've done all the steps. The only problem I think I have is the COM port setting, still a little confused on setting it. The esc reads and writes just fine with the handheld. I have a Sony Vaio Laptop, and using a usb/db9 converter to connect to the laptop. My buddy used his laptop on my esc and it worked, like I said, I think it has to be with the configuration of the port.
You will need to look at up the com port setting on your computer. The lap top that i use does not have a seriel connction so I use a USB converter. The converter changes the com port to 5. I have found that some converters do not like certain OS (operating systems). For example, an older converter may not be compatible with XP.
Like I said, you will need to look up your comport settings. Click on My Computer->System->Hardware->Devise Manager->Ports. There you should be able to find your converter port.
KO PROPO Staff is offline
Old 06-09-2005, 01:16 PM
  #902
TDO
TDO's Avatar
Originally Posted by Hebiki
maybe the program window is larger than your resolution? so its off to the side? thats the only thing i can think of.
Well I did not check that. Will do so first on my other system. problem is that my RC system does not go any higher than 1024 res.
TDO is offline
Old 06-09-2005, 05:14 PM
  #903
jdm19turn's Avatar
Default ko propo vfs-1 pro
hey guys thats for the setup info it worked great..
jdm19turn is offline
Old 06-11-2005, 09:18 PM
  #904
JayBee's Avatar
Trader Rating: 31 (100%+)
Talking
Just installed the kicazz VFS1 Pro, now all I need is a kicazz stock profile for a large flowing med.-grip track. Anybody got one that they wouldn't mind sharing? -JB
JayBee is offline
Old 06-11-2005, 11:05 PM
  #905
Alex C's Avatar
Trader Rating: 50 (100%+)
Jaybee,
Great to hear that you just purchased the best speedo money could buy!
The Person who helped me out the most was Chris Lim a.k.a (Hebiki), he was very knowledgeable on this speedo. I myself could not believe the difference between my KO-Propo and my Quantum 2.
A few guys that I race with could not believe the punch this speedo had compared to there Novak GTX, they all now are running the KO-Propo VFS-1!!
Attached below is the Stock setting that I am using for a Monster Stock, If you are running a Roar Stock just up the profile 2 steps.
On another note, I noticed that you where running your speedo past the edge of your chassis. Try to stand up your reciever and make room for the most important part of you car!!
Quote:Originally Posted by Hebiki
for stock... try this setting...
5 <--- starting point for throttle curve
5
4
4
4
4
4
4
3
3
3
3
3
3
2
1 <--- throttle half way pressed (stage #16)
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17 <--- throttle fully pressed. white knuckle and all
enjoy!
Alex C is offline
Old 06-12-2005, 12:08 AM
  #906
JayBee's Avatar
Thumbs up
Thanks for the setting!! I'm running a Fantom stock...
I don't think the speedo stickin' out of the chassis is that big of a problem. I figure that if it was a problem Corally wouldn't have spent so much time designing a chassis that places the motor out even farther
JayBee is offline
Old 06-12-2005, 12:29 AM
  #907
TDO
TDO's Avatar
One good hit from the side by another car and your speedo comes of or worse......... you'd better place it behind the motor, so the motor will take any hits. Just my 2cts and RDX cars I have seen here in NL.
TDO is offline
Old 06-12-2005, 12:40 AM
  #908
Roger's Avatar
grab the one above.. but raise the whole profile 5 stages.
When you say "raise the whole profile 5 stages ", what does that mean ? Thanks.
Roger is offline
Old 06-12-2005, 12:49 AM
  #909
JayBee's Avatar
Thumbs up
Just loaded the before mentioned stock setting. Let's see how this baby performs tomorrow -JB
JayBee is offline
Old 06-12-2005, 02:07 AM
  #910
Hebiki's Avatar
Trader Rating: 26 (100%+)
jaybee.. i obliterated a VFS-1 on my SDW because i had it sitting out like you did. trust me from experience, all my ESCs are sitting inside now. receivers are much easier to replace
Hebiki is offline
Old 06-12-2005, 02:09 AM
  #911
Hebiki's Avatar
in your handheld programmer you have an option to move the entire profile up and down. the menu is called: ALL SEL
Hebiki is offline
Old 06-12-2005, 08:10 AM
  #912
Default beeping sounds from PDS-949ICS servo
dear ko staff:
The folowings are the components for my 8T 1/12:
1. KR-297FZ 40 FM KO Receiver
2. VFS-1 Pro, default setting
3. KO PDS-949ICS servo
4. KO ex11 presto
and below are my questions:
1. There are some beeping sounds from my servo since the frist time i tried it on pit table ....why??is it normal or what?
2. what i need to take advantage of the "digital" character of my servo?
3. can i add a receiver cap? (when i do not use a receiver pack...of coz)
4. if i am minded to avoid glitching/jamming due to over motor amp draw...should i tune UP the BEC in my VFS1 (4V), or tune it down?
thanks a lot.
RC12L3a is offline
Old 06-12-2005, 08:54 AM
  #913
Is it possible to use the Setting adapter with the setting card from the VFS-1 Pro Value Pack with a Hara Twister 2 Version 2.1 ?
darulor is offline
Old 06-12-2005, 10:25 AM
  #914
I figured out my problem, I was missing the USB Controller driver. But now it's all good, I am upm and running on the laptop! Here's the pic of my FK05 with the VFS-1 i it. Thanks Hebiki for sharing set ups and everyone who replied on my problem.
NorCal_Big_L is offline
Old 06-12-2005, 10:19 PM
  #915
Hebiki's Avatar
yes you can.
Hebiki is offline
