Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 06-06-2005, 01:51 PM
  #886
V12
V12's Avatar
Originally Posted by Hebiki
yes..3.980khz. ill post the frequency comparsion chart on here.
the new Ko VFS has a carbon graphite looking case. the thermal shutoff feature has been removed. its called VFS-1 Competition
thats all i know. ill find out more this week.
VFS-2 replaces the KSC-1200 series escs.
Hebiki
Did you hear anything new on the VFS-1 Competition?
When will this be available and how much will cost more?
Maybe any other differences then the thermal shutoff feature removed?
Thanks.
V12 is offline
Old 06-06-2005, 02:40 PM
  #887
FW-05RR's Avatar
Chris or Robert when is the new speedo and RX from KO with the sweet carbon fiber finish coming also will they sell for the same price as the current vfs-1 pro and the 302f?
sorry if this has been answered already
FW-05RR is offline
Old 06-06-2005, 03:45 PM
  #888
Originally Posted by berger
I find you need to let the throttle in a little slower, i have to admit in the heat of it all i throttle jam a touch, but provided you dont then it should be okay.. Were the brushes discoloured or was the motor just really hot? As long as it doesnt fade over the 5 minutes i dont worry too much about the motor temp now!
I am going to open it up today and check. There was no fade. Just smelt burnt! Quite a few noticed the burning smell.
NorCal_Big_L is offline
Old 06-06-2005, 06:04 PM
  #889
jdm19turn's Avatar
Talking looking for a good 19turn setup for vsf-1 pro
looking for setup for the vfs-1 pro iam currently using the default setup in the esc iam runinng in 19turn class looking for alittle setup advice..
jdm19turn is offline
Old 06-06-2005, 06:13 PM
  #890
Hebiki's Avatar
Trader Rating: 26 (100%+)
grab the one above.. but raise the whole profile 5 stages.
Hebiki is offline
Old 06-08-2005, 02:30 PM
  #891
TDO
TDO's Avatar
This evening the first real time to try out different settings for the VFS-1 in combination with 19T handwound Corally motor, geared at 5.5 on a trf415. My hometrack is 'high speed' track www.amcaracing.nl.
Whoa, with all the diff. settings you can really see what a esc can do, especially this one. I ended up with the basic 19T high speed setting which can be downloaded from the Ko site with some adjustments to the neutral brake and the first steps of the settings.
We even tried to hook up a Hara Twister, with no problem and the guy running this was pleased that I brought my laptop
This VFS-1 is def. the speedo to get!! Can't wait until my other speedo QC2 will burn out
TDO is offline
Old 06-08-2005, 04:24 PM
  #892
Originally Posted by V12
Hebiki
Thanks.
The VFS1 competition is normally available, I have received my Twister 2.1 a weeek ago. Price is very similar to actual VFS1 Pro
Ralf is offline
Old 06-09-2005, 01:36 AM
  #893
TDO
TDO's Avatar
Something else. I already send a mail to Ko in the US, but perhaps someone got the same problem and knows the solution.
When I start the VFS-1 Manager 2.2 software the right side of the program is not visible, so I cannot change the com setting, neutral brake etc.
I run the program on an old Toshiba CTX4060 at 1024 resolution (maximum).
Who experiences the same problem and who has the solution?
Marc
TDO is offline
Old 06-09-2005, 01:40 AM
  #894
jarkkom's Avatar
TDO, make sure that the COM port is enabled on your computer.
jarkkom is offline
Old 06-09-2005, 01:48 AM
  #895
TDO
TDO's Avatar
Com is functioning perfectly, but I had to select it through the ini file. It is just that the program-screen is cut off at the right side.
TDO is offline
Old 06-09-2005, 06:59 AM
  #896
I downloaded the software and tried to use it. When I start the program, I get a pop up that says "COM 3 Complete". Then when I go to read or program a setting, I get a "Communication Fail". Can anyone help me?
Old 06-09-2005, 07:08 AM
  #897
berger's Avatar
You need the cable to connect from the computer to the device, without it you cannot use the software.
berger is offline
Old 06-09-2005, 07:12 AM
  #898
TDO
TDO's Avatar
First some questions:
Did you hook up the esc to the cable connected to the pc?
Did you switched the esc on while holding the set button?
Did you connect the esc to a bat.pack?
When you connect the esc to the cable and the bat.pack then hold the set button and power on the esc. Wait for the red led to go out en then on, release the set button. You should now be in the read/write mode of the esc.
If this doesn't work look in your pc settings under configuration / system what the number is of the com port. Go to the vfs.ini file and set the value to the appr. number.
And if that doesn't work...................well call to get a new VFS-1
Marc
TDO is offline
Old 06-09-2005, 12:05 PM
  #899
I've done all the steps. The only problem I think I have is the COM port setting, still a little confused on setting it. The esc reads and writes just fine with the handheld. I have a Sony Vaio Laptop, and using a usb/db9 converter to connect to the laptop. My buddy used his laptop on my esc and it worked, like I said, I think it has to be with the configuration of the port.
Old 06-09-2005, 12:09 PM
  #900
Hebiki's Avatar
Marc
maybe the program window is larger than your resolution? so its off to the side? thats the only thing i can think of.
Hebiki is offline
